you are reusing that crank??!
It Begins...... Minus.
#646
Posted 14 July 2014 - 06:43 PM
#647
Posted 14 July 2014 - 07:53 PM
Long time no see!
Beautiful.
Ed
#648
Posted 15 July 2014 - 06:30 AM
She's a go'r. Lol.
Cleaned up ok. I'm building another engine so it won't be run for to long.
#649
Posted 16 July 2014 - 06:33 PM
this is FIT!
#650
Posted 18 July 2014 - 05:47 PM
Thats does look pretty special now.
Nice job on that
#651
Posted 20 July 2014 - 07:38 PM
She's a go'r. Lol.
you are a trooper! thats most of the taper taken up, id not be supprised if the flywheel spins under heavy load at some point! id get cracking with the next motor!! or find someone with a mint 1300 crank ready to go with bearings to suit.. wonder who would have one of them....
hang on..
#652
Posted 22 July 2014 - 05:25 PM
this looks the nuts !!!! would potentially be the only other car I would have instead of the pickup !!! what Fibreglass body is it ???
Robbie
#653
Posted 25 July 2014 - 07:34 PM
She's a go'r. Lol.you are reusing that crank??!
hang on..
Lol, its not that bad, it's not damaged all the way round. Seems to be running alright, done nearly 80 miles on it!
I have another crank for my turbo engine, I've wedged and semi-knifed it. Just needs balancing.
#654
Posted 25 July 2014 - 07:35 PM
Robbie
It's a Minus. As in my title ;).
#655
Posted 25 July 2014 - 09:10 PM
Robbie
i understand its a minus lol , as in who made the body ? was it a kit, as I thought the orginal minus's were steel too like a normal mini
#656
Posted 25 July 2014 - 11:06 PM
It's a Status motor company minus. No only grp! Never steel.
http://www.miniminus.co.uk/history.htm
#657
Posted 26 July 2014 - 02:59 PM
Pretty happy with that. Suppose I should start drilling holes everywhere! Quite a bit more to come out with alloy parts etc.
#658
Posted 29 July 2014 - 12:03 PM
Need some better trim.
Also, definitely need to move my switch panel, harness on, can't reach anything!
The rear protech coilovers are quite a low spring rate, I bought them as that's what they recommended with a light car. I did not take into account my seating position is much further back so with two people it puts to much weight over the rear. In short I need some heavier springs as it rubs a fair bit.
Finally, internal linkage rattles like made at a certain speed/rpm. Seen a few people modify them with solid bushes and a sleeve in the front, so need to do that. It also comes to far over and you can nearly select reverse without lifting the collar on the stick. Bit of a pain but I should be able to move the plate at the bottom over.
Put some grip tape on the floor.
#659
Posted 30 July 2014 - 12:37 PM
#660
Posted 30 July 2014 - 02:05 PM
Are you likely to be going to Castle Combe in September as id love to see her in the flesh?
