It Begins...... Minus.
910 replies to this topic
#601 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 29 May 2014 - 02:37 PM
You could fit a bleed nipple into the top hose as that looks like it would be the highest point.
Looking cool nice to see you are cracking on .
Is it just the photo and I am no expert but if your rad is lower than your thermo hosing you will need to fit a expansion bottle ....... (higher) ......or you will end up with a huge air lock problem
Sorry if I am wrong or if I am teaching grandma to suck eggs
Its all good, i've got a expansion tank on the bulkhead. Supplied by the No.4 heater feed. This runs back into the rad overflow (overflow is on the expansion now). This should help keep around No.4 a lot cooler to.
#602 jonny f
jonny f
  • 1,485 posts
Posted 29 May 2014 - 02:39 PM
Freaken loving this thing haha. Its pure car porn. Take me for a spin in it when you've finished it please :)
Should be done in a couple of months!
#603 mm man
mm man
  • 404 posts
Posted 29 May 2014 - 08:03 PM
I knew there would be a plan! Sounds good to me
Where there's a minus owner there's always an alternative plan
As I say good work
Two months and counting ...........
#604 MrBounce
MrBounce
  • 2,638 posts
Posted 29 May 2014 - 09:45 PM
1601203_10152521355831654_86189388607712
That is one damn sexy plastic car!! :thumbsup: :P :wub:
#605 jonny f
jonny f
  • 1,485 posts
Posted 30 May 2014 - 12:47 PM
Engine bay all done.
Pretty happy with it. Could do with some different leads.
Might have driven it to ;).
10320605_10152528600791654_8204099291195
#606 Rocket.
Rocket.
  • 1,441 posts
Posted 05 June 2014 - 09:03 PM
Love this ! :wub:
#607 jonny f
jonny f
  • 1,485 posts
Posted 07 June 2014 - 08:19 PM
Thanks chap.
Passenger ones. May have to raise the ride height a little on spirited driving there is a fair amount of clearance though.
I do need to re-do the front drivers, did the passenger one a bit different and it looks a lot better where it wraps around.
10303460_10152543454786654_9115433325307
Rear parcel shelf in, need to seal it.
10418392_10152543454791654_5203659360885
Changed the inside lines to flexi ones, easier on the eyes. I've changed both rear cylinders for ones with bigger bleed nipples (stripped the thread on one of the old ones!). Also got the hydro working correctly now.
10411803_10152543454796654_9050275347397
#608 jonny f
jonny f
  • 1,485 posts
Posted 25 June 2014 - 04:04 PM
Been doing the body this week. I am doing this on the cheap side of things with help from a painter...
Rubbed down the etch primer ready for high build.
10338647_10152590166771654_3812113451894
High build on and guide coated.
10492241_10152590777791654_2059533633749
flatted back ready for top coat.
1532081_10152592261186654_51220460044364
Doors bonnet and boot have had the same treatment and a 2/3 coats of 2k. Also flatted and polished them. Not got a finished picture.
10383743_10152592261816654_8671218602188
The body, flatted back on the roof, will do the rest tomorrow and give it a good polish.
10481551_10152592876831654_3545489537158
Its a perfectly presentable finish but not show winning by any stretch.
My plan being that some of my repairs might crack and move so if (read when) that happens i'll probably paint it again.
#609 Baldspeed Racing
Baldspeed Racing
  • 1,191 posts
Posted 26 June 2014 - 06:46 AM
fair play mate, hope the paint holds up but I guess its hard to tell with the FG shell. Looking forward to more pics as usual :)
#610 jonny f
jonny f
  • 1,485 posts
Posted 26 June 2014 - 09:44 PM
Bought it home today after a flatting and polishing.
10457380_10152594849991654_1690540360884
Got both the doors built up.
10357731_10152596130676654_2812576013351
Started fitting everything to it. Wired up the rear lights, but cocked it up somewhere! Think my CBS module could be wired up incorrectly/drawings wrong. Indicators all work correctly and the hazards but the fuse is blown and i've got no side lights!
10459104_10152595338211654_2331129398042
#611 kel
kel
  • 34 posts
  • Local Club: Sheffield mini owners
Posted 26 June 2014 - 10:10 PM
I'm in love
#612 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 June 2014 - 03:12 AM
Maybe, but don't neglect earths on a grp monocoque. I ended up with a thick gauge battery wire from front subframe to back subframe, one from battery to rear sub. A thick guage wire from rear sub to a terminal in boot, for all rear lights etc. Earth to front sub from engine (as normal), with a separate earth from front sub to a terminal behind the dash, using another big fat battery wire, for all the dash stuff to earth to, along with front lights etc.
Otherwise you'll be chasing electric gremlins endlessly. I had the horn only working when the indicators were on and all sorts of weird *******.
Edited by Alburglar, 27 June 2014 - 03:19 AM.
#613 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2014 - 08:29 AM
I've battery cabled from engine to subby at the front then to the cage and from cage to battery at the back. Only got thin gauge in the back for earths, maybe I'll go up a size, I'm fairly certain my earths are good! I'm supposed to be an electrician lol.
See if I can sort it today, fingers crossed
#614 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2014 - 10:40 AM
Fixed it!
#615 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2014 - 04:52 PM
Sorted out the rear lights, got the rear screen in and wired/fitted out the front end. Just need to tidy up the wiring a bit.
10404025_10152597905351654_2591768984204
10275420_10152597905641654_5592531576736
