It Begins...... Minus.
910 replies to this topic
#586 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 01 May 2014 - 10:59 PM
could you not have that remade or trim it down to go directly to the rad ?
also, is that the final mounting area for the oil cooler ?!, if so you could tidy things up moe by getting a shorter cooler pipe ? as the rest is just soo clen and neat seams out of place haha
Great work and very unique build
I made it up myself just out of ebay hoses. I can't think of a neater way without modifying either the rad or stat housing.
The trouble is the height difference and position. the rad bit points directly at the stat housing and is lower.
I might try some flexi water hose, see if thats any better.
No the coolers not staying like that, not sure where i will put it yet, i'm undecided!
Edited by jonny f, 01 May 2014 - 11:00 PM.
#587 jonny f
jonny f
  • 1,485 posts
Posted 01 May 2014 - 11:04 PM
Had some help from the misses this morning. Manged to get the tunnel heat protected.
1557333_10152464539146654_72398314497283
Got all the brake lines and a hydraulic handbrake in place. Just need to hold the lines in a few places.
10321813_10152464538951654_3104904438954
10171736_10152464539176654_5672451406771
The rear line goes into a T piece in the boot then out to the longer goodridge hoses.
1002885_10152464539211654_72899721798570
#588 kcchan
kcchan
  • 874 posts
Posted 02 May 2014 - 06:50 AM
Can you just get a nice tight 90deg in there and trim it close to the bend? You may even be able to use the one you have and trim it. It's all coming along now.
Edited by kcchan, 02 May 2014 - 06:51 AM.
#589 jonny f
jonny f
  • 1,485 posts
Posted 02 May 2014 - 09:59 AM
No its hard to see in the picture but the rad bit sits behind the stat housing and below it. I was thinking get the rad changed so its at the other end and then rotate the stat housing (use a normal housing and a different engine steady).
#590 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 02 May 2014 - 11:25 AM
whats made you put the handbrake on the right hand side?
#591 jonny f
jonny f
  • 1,485 posts
Posted 02 May 2014 - 01:30 PM
Best position i could get it in. On the other side it would be to far away or get in the way of the gear lever.
#592 domdee
domdee
  • 1,183 posts
Posted 02 May 2014 - 02:18 PM
oh right cool
#593 rally515
rally515
  • 3,848 posts
Posted 02 May 2014 - 03:14 PM
Hmmm, shame you've got a sexy billet themostat housing, otherwise i would have said send it to me and i'l tig weld the top round 30 Degrees so you can stick a straight tube on there...
#594 leaky
leaky
  • 6,890 posts
Posted 03 May 2014 - 11:56 AM
I love some smart and tidy everything looks. Feel free to come round and do my brake lines haha. I am worried I'll bend them wrong and they end up looking naff!
#595 jonny f
jonny f
  • 1,485 posts
Posted 03 May 2014 - 03:49 PM
Thanks for the offer. Think i'll get the rad modded.
I think the photos do it better justice lol.
I found it easier to use an old bit of copper brake pipe i had and bend that into shape first. Then copy it with the new stuff. Cupro-nickel is also better to work with.
#596 jonny f
jonny f
  • 1,485 posts
Posted 27 May 2014 - 05:09 PM
Pictures to show my headache.
1907999_10152521355661654_85699012987142
10375044_10152521355676654_2813557540142
Column is in. My MK1 inner was shot. The lower spline didn't hold on the rack. So i robbed the inner off a mk3 column. Did not take to much modding to fit. Now i have the better lower bush.
Drilled for the mk1 indicator thingy.
10365727_10152521355671654_9206096152198
Dash is also in, didn't like it in the centre, now its right in front its easier to see. Not much space for it to fit in. Loom is also pretty much done. Hidden it all down the inner wing.
10375044_10152521355656654_4169170302422
Accelerator pedal is in. Had to make a bracket to bring it forward and mod the cable.
10338699_10152521355666654_5958777877793
Two rear lower steadies in.
10334241_10152521355846654_4258694398702
I gave up on using the mini handbrake and got this of a mate. Came from a suzuki SJ. Easier to use. It won't be used in anger.
10313804_10152521355836654_3163108284110
Fitted with threaded bar instead of a cable as it sits a lot further back.
10305055_10152521355851654_1892990220753
Trimmed arches down, i need to mount the brackets for them next.
1601203_10152521355831654_86189388607712
Edited by jonny f, 28 May 2014 - 04:12 PM.
#597 jonny f
jonny f
  • 1,485 posts
Posted 27 May 2014 - 05:16 PM
Hand brake from the top side.
10325725_10152522172421654_4529353272046
Two arches done. Need a little more adjusting but i'm pretty happy.
10406454_10152522172431654_5687120479057
10365898_10152522172416654_3330331299505
:D
1514958_10152522172426654_91124235899748
#598 mm man
mm man
  • 404 posts
Posted 28 May 2014 - 09:03 PM
Looking cool nice to see you are cracking on .
Is it just the photo and I am no expert but if your rad is lower than your thermo hosing you will need to fit a expansion bottle ....... (higher) ......or you will end up with a huge air lock problem
Sorry if I am wrong or if I am teaching grandma to suck eggs
#599 leaky
leaky
  • 6,890 posts
Posted 28 May 2014 - 09:18 PM
Freaken loving this thing haha. Its pure car porn. Take me for a spin in it when you've finished it please :)
#600 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 29 May 2014 - 12:03 PM
You could fit a bleed nipple into the top hose as that looks like it would be the highest point.
