It Begins...... Minus.
#556
Posted 05 January 2014 - 09:25 AM
#557
Posted 05 January 2014 - 06:50 PM
id be gluing thatally panel in with tiger seal!! bolts? pah!
#558
Posted 05 January 2014 - 07:30 PM
#559
Posted 05 January 2014 - 07:35 PM
mines all glue
ive used plastic bolts for my switch panel and a few other things in the racer. theyre lighter than aluminium and hold fairly well
ingenuity at its best no?
#560
Posted 05 January 2014 - 08:49 PM
#561
Posted 09 January 2014 - 10:40 PM
2mm may be a stretch, but your welcome to try it. I may have enough 1/1.2mm ally laying about if you wanted to go thinner?
I think I'll just leave it as it is.
It's very kind of you though! I might give you a shout if i do find anything to bead though.
#562
Posted 09 January 2014 - 10:42 PM
Bought some seats.
Cheap and cheerful, but they don't weigh to much and are skinny.
#563
Posted 10 January 2014 - 09:57 AM
Where did the seats come from? How cheap?? Minus looks amaxing so far - been keeping an eye on this build..... Wheel envy!!
#564
Posted 10 January 2014 - 05:57 PM
I like your fluffy pink slippers jonny. I like how the builds progressing I hope to pull my thumb out and do an update soon as my threads not dead just yet!!!
Regards Blue
#565
Posted 10 January 2014 - 06:14 PM
Fitted one arm today, then it started raining so haven't done the other.
work perfectly.
I've also shed a lot of weight with these. About 3.5kg in total.
sexual arms!
#566
Posted 12 January 2014 - 10:18 AM
Thanks.
From demon tweeks. £308 a pair using discount code ebay4 for 10% off. Have to be quick though the code runs out soon.
#567
Posted 20 January 2014 - 10:53 PM
Painted my window edges.
Did the rear screen to. Its to hide the seal.
#568
Posted 01 February 2014 - 10:29 PM
have a look at my minus it might give you some ideas .
#569
Posted 09 February 2014 - 05:57 PM
Love it!
#570
Posted 25 April 2014 - 07:58 AM
Not touched the car for a while, being dropped of for its cage on the 7th. :).
I am planning on using the 1380 before using the 1330 turbo but at this rate i might just use the turbo and sell the 1380 or keep as a spare.
I got a head of 'trailslife'
reduced its BHP potential and painted it BMC green instead though!
Had a few issues with the primary gear, floating bushes are not meant for most SC gears.
Not knowing that when i bought the floating bush i ended up getting the bush turned down with a small step to allow oil out if it goes over the oil holes. Also modded the oil holes in the gear. Only time will tell how it holds up.
Its fits :)
Stripped the paint of the block. Used rustins strypit, half the price of nitromors seemed to do a good job.
Half way through dry decking the block, just need a new tap.
Tapped out the block holes to 5/16th UNF
Casting marks relieved.
Gear box has come on fast.
Shiny bits...
Changed over to all A+ bits for extra strength.
Genuine 60's steel baulk rings from guess works next to what i removed. Not sure what they were. Some are worn though.
Swiftune layshaft.
Getting there need to shim the layshaft as its just out at 7 tho.
Also pretty much all the other bits have been blasted, lightened and painted. Wok and drop gear casing took forever to blast. Previous owner liked red hammerite to much.
Cheers.
