It Begins...... Minus.
910 replies to this topic
#511 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 19 September 2013 - 03:14 PM
F
Edited by jonny f, 12 July 2014 - 11:19 PM.
#512 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 19 September 2013 - 03:19 PM
Will have to look into these arms! Certainly help the clearance issues
#513 jonny f
jonny f
  • 1,485 posts
Posted 19 September 2013 - 03:49 PM
For sure. I just asked Carl to extend the coilover mounting point out 25mm and drop it 5mm.
I'm sure he could move it anywhere though.
#514 jonny f
jonny f
  • 1,485 posts
Posted 26 September 2013 - 07:06 PM
First coat of primer on, pretty much.
Just need to do the door shut on the other side. Quite a few bits that will need some more filler before another coat.
1265700_10151963700551654_1593758847_o.j
#515 blue blood
blue blood
  • 806 posts
Posted 26 September 2013 - 08:57 PM
bloody hell in primer already I had better pull my thumb out and start doing something to mine!!! keep up the good work Jonny.
Blue
#516 thelegg
thelegg
  • 608 posts
Posted 26 September 2013 - 10:32 PM
wow didn't see that one coming lol well done to you :)
#517 Minidarren83
Minidarren83
  • 1,207 posts
Posted 28 September 2013 - 01:53 PM
Looking good jonny all the hard work is starting to pay off
#518 steven
steven
  • 1,195 posts
Posted 30 September 2013 - 08:28 PM
looking good :thumbsup:
#519 jonny f
jonny f
  • 1,485 posts
Posted 01 October 2013 - 01:50 PM
Thanks guys, I've now gone round it with some dolphin glaze filling all the little imperfections ready for another coat.
#520 jonny f
jonny f
  • 1,485 posts
Posted 06 October 2013 - 04:57 PM
Its had another coat of primer on the outside. Still far from perfect, hopefully some high build will help when I've got a cage sorted.
Going to prime, stonechip (using gravitex) and top coat the underside soon. Hence this happened today, along with lots of rubbing down. Shells pretty easy to lift up like this on my own, luckily!
1184971_10151992532606654_729727215_n.jp
#521 bpirie1000
bpirie1000
  • Area Managers
  • 2,341 posts
  • Local Club: Amoc
Posted 06 October 2013 - 05:23 PM
1292076_10151947293821654_1614627234_o.j
Can you get the radius arms done in this style as well? Who did them and a rough cost? Or did you design if so any drawings?
#522 leaky
leaky
  • 6,890 posts
Posted 08 October 2013 - 10:17 PM
Jonny your mini seems to have fallen over.
#523 jonny f
jonny f
  • 1,485 posts
Posted 09 October 2013 - 07:46 PM
They are from Force Racing.
Got caught by the wind :o
#524 jonny f
jonny f
  • 1,485 posts
Posted 11 October 2013 - 04:02 PM
Another update...
stonechip is done! i used upol 1k acid etch in rattle cans (used 3) and then gravitex (4.5L overall) in 1L bottles that screw straight on the bottom of the under body spray gun i had.
Its come out really well. I like the textured look. I'm tempted to use it in some areas on the inside with a little thinner in so it goes on a bit smoother.
I did one full coat on the under side and then another coat or two in the areas that would be worst affected by stones.
I need to put some colour over it to but i need to make my mind up!!
1274703_10152003441286654_695325391_o.jp
I had to rebuild around the steering column bit that's why a few holes are missing.
#525 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 11 October 2013 - 04:13 PM
Very nice :gimme:
