It Begins...... Minus.
#391
Posted 14 March 2013 - 07:07 PM
#392
Posted 14 March 2013 - 07:14 PM
How you doing the internal wiper motor man? Always thought they ruined the look of the engine bay.
Just cut a hole in the bulkhead and run the wiper line through. You need to bend it which is the hard bit. Can't bend it to much though otherwise the wire part gets stuck as it can't do to tight turns.
Kinda hard to explain really lol. With the wiper off its easy to see and understand what to do with it.
Was a bit of a ball ache for me as there is zero room between the top and bottom dash rails. Should be easier for you.
#393
Posted 14 March 2013 - 07:21 PM
Edited by jonny f, 12 July 2014 - 11:12 PM.
#394
Posted 14 March 2013 - 10:55 PM
Regards Blue
#395
Posted 15 March 2013 - 01:32 PM
#396
Posted 15 March 2013 - 04:31 PM
Was gonna have another read through of this but all of your pictures are gone!
I second that! Any chance you could fix them
#397
Posted 15 March 2013 - 05:40 PM
I second that! Any chance you could fix them.
It's Facebook
I think they must have changed them all when it went to the newer photo thing
#398
Posted 16 March 2013 - 01:51 PM
#399
Posted 16 March 2013 - 01:59 PM
I doubt the pictures have moved, you probably need to change the permissions on the album.
All my pictures are from the same album that's set as only friends can see it, when you share the URL anyone can see the picture though. The olders ones went when it changed to the newer photo viewer thing I think.
#400
Posted 16 March 2013 - 02:17 PM
If you go through your pictures and edit the URL to the image at the start, change it from:
sphotos.ak.fbcdn.net
To:
sphotos-f.ak.fbcdn.net
That will fix most of them. I've already done the first two pages of your thread.
It'll help if you flick the little light switch off at the top left of the editing window.
#401
Posted 16 March 2013 - 02:52 PM
Had another look.
If you go through your pictures and edit the URL to the image at the start, change it from:sphotos.ak.fbcdn.net
To:sphotos-f.ak.fbcdn.net
Thank you very much for that! I'll sort the rest out soon. Saves me a bit of time to as I was going to copy each URL from Facebook again!
I had looked at the URLs before but didn't notice that difference.
#402
Posted 16 March 2013 - 03:45 PM
Had another look.
It worked for the first 4-5 pages but it won't work on page 6
#403
Posted 16 March 2013 - 05:56 PM
Like this:
http://sphotos-f.ak....633837993_n.jpg
Although thinking about it I'm not sure how long it would be until the links broke again as Facebook doesn't actually offer hotlinking as a sharing method so they might change it every now and then to prevent that.
Have you considered Photobucket?
#404
Posted 19 March 2013 - 12:58 PM
You'll have to delete the bit before sphotos.
Like this:
Ahhh thank you again.
No i haven't, i do have a flickr account.
#405
Posted 19 March 2013 - 01:04 PM
