I actually face booked them and they said they used the bigger ratio one of the 6.25 to 1 ratio as opposed to the 5.1 to 1 ratio!!! So I think I will go with the 6.25 one and have the fancy looking pedals this one:
http://www.wilwood.c...heets/ds762.pdf
as opposed to this one:
http://www.wilwood.c...heets/ds226.pdf
Have you sent money to JB for a pedal box then?
Regards Blue
Well i guess the 6.25 gives more power as such. If i got it the right way round?
No i haven't he is working from a standard pedal box so i'm going to wait and see what he comes up with.
Love the work!
You sure the composite engine steady bracket etc will be good? Not going to fatigue or the glue come apart?
Also, swan neck
. Can you not get some sort of weber box I
On it if you have to use a weber?
The steady came from Arc angels, so i would imagine its been tested... he says haha.
Yea i want to see how well it fits first, i know there not the best manifold but its probably better than the HIF44 and i could port it a bit. I am tempted by cutting the bulkhead and putting a box in but i'm not to sure!
