It Begins...... Minus.
910 replies to this topic
#226 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 29 October 2012 - 10:17 PM
Hi jonny it looks like it has a come a long way since I saw it when collecting the subframe off you it looks like it bill be a very nice car when it's done
Darren
Thank you Darren!
Did not know you were on here. Will have a look for your build shortly.
#227 jonny f
jonny f
  • 1,485 posts
Posted 29 October 2012 - 10:27 PM
I saw that kit too and had a guy on the 16v forum take a picture of it:
http://www.16vminicl...ead.php?t=30877
It is a fair chunk of change and I wondered if I could maybe nock one up for less with something like this:
http://www.rallydesi...roducts_id=4075
and using this as a reservoir as it has a float built into the cap already and you only have one overall level to keep your eye on:
http://www.motorspor...t-p-246758.html
Regards Blue
It does look the dogs do dars though!
I contacted rally designs to see if they could get the same as what mini-tec produce and they said mini-tec must modify one of the wilwood kits to suit a mini.
I would not think it would be to hard to do something with a universal one as long as the pedals sit at the right height/angle?
#228 jonny f
jonny f
  • 1,485 posts
Posted 30 October 2012 - 10:22 AM
Rear screens in
#229 jonny f
jonny f
  • 1,485 posts
Posted 30 October 2012 - 05:06 PM
c
Edited by jonny f, 12 July 2014 - 11:00 PM.
#230 blue blood
blue blood
  • 806 posts
Posted 30 October 2012 - 05:27 PM
Bloody hell Jonny your on a roll of late. Good work.
Blue
#231 jonny f
jonny f
  • 1,485 posts
Posted 30 October 2012 - 05:48 PM
I know! soon to be halted no doubt. Waiting for the rad to turn up so i can get the inner wing sorted.
Probably going to fit the door windows in the next few days when i get some time.
need to keep at it.
Edited by jonny f, 30 October 2012 - 05:49 PM.
#232 NRB
NRB
  • 16 posts
Posted 30 October 2012 - 08:42 PM
good progress Jonny
#233 kcchan
kcchan
  • 874 posts
Posted 30 October 2012 - 09:35 PM
Great stuff. I might switch from the heavy glass rear screen for something similar.
Me likey
#234 jonny f
jonny f
  • 1,485 posts
Posted 31 October 2012 - 02:19 AM
Me likey
It's a good way to save a lot of weight from up top where it matters more. Can also bolt them in for a different look ;).
#235 kcchan
kcchan
  • 874 posts
Posted 31 October 2012 - 07:56 AM
Yea I was thinking about a bolt in one, lose the heavy rubber as well.
Only trouble is, I'm worried my back end will be too light. All my weight saving seems to be up front on my build.
Minus screens are smaller than normal aren't they?
#236 jonny f
jonny f
  • 1,485 posts
Posted 31 October 2012 - 11:13 AM
I'm not sure what the difference is that I have actually saved going bolted. I could have used less bolts in the rear screen though.
No they are the same size as a mk1. My rear had been made out to a mk3. Now it's somewhere inbetween.
I think the rear quarters may be a little smaller than a mk1 but I had mine made from a template.
#237 kcchan
kcchan
  • 874 posts
Posted 31 October 2012 - 12:44 PM
you could use less bolts or you could get some nice fancy alloy ones (or both!)
The windscreen rubbers are just over 1kg
#238 jonny f
jonny f
  • 1,485 posts
Posted 31 October 2012 - 02:04 PM
I'm planning on slowly swapping out to alloy ones when I have finished.
I could have probably got away with half the amount I have used on the rear screen.
I've definitely saved some weight going bolted then! You know how much the rear quarter ones weigh?
#239 jonny f
jonny f
  • 1,485 posts
Posted 31 October 2012 - 02:09 PM
Just weighed everything I have for fitting the door, rear quarter and rear window. 420g for the nuts/bolts and daming tape. Probably a considerable saving.
#240 kcchan
kcchan
  • 874 posts
Posted 31 October 2012 - 02:10 PM
There's a list that's been compiled on turbo minis. I bought some poly windows from blue blood but I might sell them on again for some bolt in ones.
