Collected this yesterday...
Basically, it will be my current mini, but blue and more of a MK1 style.
Been busy today stripping an old race shell. Will have some updates soon.
Edited by jonny f, 02 July 2014 - 09:54 PM.
Posted 15 December 2010 - 09:35 PM
Posted 15 December 2010 - 09:36 PM
Posted 15 December 2010 - 09:40 PM
good luck always liked the low look of a minus
Posted 15 December 2010 - 09:47 PM
I'll need it!
Posted 15 December 2010 - 09:52 PM
Posted 15 December 2010 - 10:06 PM
Edited by Mini-jon, 25 December 2010 - 08:20 PM.
Posted 15 December 2010 - 10:08 PM
Posted 15 December 2010 - 10:35 PM
Posted 16 December 2010 - 09:20 PM
Posted 16 December 2010 - 09:54 PM
yup its poly windows in the back. The front windows do not 100% if you take a close look because the top of the frame is modified as well. It is cut down on the sides and then in the middle so making it smaller but the windows still make a good enough sealWell the the rear quater windows are not the standard size! I thought they should be but there at least an inch to big. The windows dont even fit in the recess let alone the lip for the seal :/
Posted 17 December 2010 - 02:29 PM
Posted 17 December 2010 - 03:11 PM
Posted 17 December 2010 - 09:46 PM
I looked into fibreglass doors but then decided not to go with them as hey are very flimsy and you can't use glass or a wind up mechanism. Plus the only company that sell them which is arc angels have copied a pair of doors which were repairs of originals which doesn't make for a good fit. Also i personally don't like the bottoms on them as they look like they are missing the bottom lip like on normal mini doors which surrounds all of the door card, and also would compromise giving a good water seal with the rubber door seals as the rubber would be floating on the bottom not butted up against a raised bit on the door like in normal sized cars. What i have done is rebuild my doors and use the replacement panels for the bottom of a normal mini door and making a nice curve instead of just chopping it of like a hack job and welding a flat piece on the bottom and hammering or completely cutting a piece out on the bottom corner of the door which is what the minus people did when they made up the doors. To be honest i'd go for steel doors still. I am personally going to have mine dipped and e coated so they are completely covered. I have the advantage of one of the only places that do it in the U.K are up the road from meAhh thanks for that. Makes sense, I was getting worried. Hopefully im getting a set of fibre glass doors so I won't have to mess about fitting steel ones.
Posted 17 December 2010 - 11:47 PM
Posted 22 December 2010 - 09:48 PM
Edited by tedmcedd, 22 December 2010 - 10:02 PM.
