My Mini ;) The Third Chapter. 998 Fast road.
#796
Posted 23 November 2012 - 10:13 AM
If he could tell you what the problems were then he new they were there and ignored them, that's a big fault on his part.
#797
Posted 23 November 2012 - 01:18 PM
There was no visible rust at all, I made sure of that. But clearly it was in the seams and I hadn't treated the rust properly when I'd taken the paintwork back to bare metal.
I can't swindle a free repspray from him (I wish), so I'm best to crack on and set it straight.
I'll definitely hit back harder & stronger.
I think tonight I'll start by taking her apart again, the front end first as that's the most affected.
Although seeing that rust come through had now knocked my confidence with the rest of the shell and wether it'll start to rust through soon.
I'd love to be able to get it dipped / blasted & start from scratch & do a proper thorough job this time. We'll see.
Edited by analogue_radio, 23 November 2012 - 07:17 PM.
#798
Posted 23 November 2012 - 04:47 PM
keep your head high mate you have a gorgeous mini!
#799
Posted 23 November 2012 - 04:52 PM
I told at that time he'd receive the shell in a stage where it's ready to prep & paint. It was largely covered in red oxide where I thought I had at that time cleared & treated the rust.
mate, that sucks.. but as everyone says, if he is such a good bodywork guy, then he should have made sure his 'canvas' was solid and ready for paint!
and i think unless you do take it right back and start afresh you will always doubt it, there will be that horrible feeling in the back of your mind..:/ it has happened with me, built my engine all up and am now doubting the STD con rods in it. just cant afford for one to break so i am pulling the whole thing apart to fit some steel H beam ones.
for a point of referance i got a good blasting job done for £250. so its not TOO dear..
#800
Posted 24 November 2012 - 09:51 PM
I have been watching with interest the comments made by various contributers and now consider the time right to set the record straight.
Luke commissioned me to paint a self repaired mini saloon shell. In addition I was commissioned to replace recently poorly fiited A panels and to reskin the drivers door due to previous person doing it and seriously distorting it.
I was advised that all the corrosion had been correctly delt with by either metal replacement or effective chemical treatment. Luke had done this himself in order to minimise the costs and at the time believed he had done an effective job. I had no reason to question his work.
The shell was provided to me, unusually in a red oxide primer with no signs at all of corrosion or surface rust.
Presented in this state there was no way of knowing if this was so without stripping the shell back to bare metal which Luke did not want me to do.
On this basis the shell was prepared for painting in the normal way with hight build primer which itself was then prepped for top coat. The job was finished 18th December 2011.
Examination now of the photo's Luke took of the car when he first brought it indicate the corrosion was in evidence in most of the places minis tend to rust. Corrosion has now started to re-appear in those places, e.g under head lamps. There is no sign of rust or corrosion on any of the steel that i put on the shell and prepped completely myself.
I have every sympathy with Luke and as he has already indicated I have offered advise if he wants and assistance to rectify these corrosion issues effectively this time.
#801
Posted 24 November 2012 - 10:43 PM
Starting to strip down the front.
#802
Posted 24 November 2012 - 10:45 PM
#803
Posted 24 November 2012 - 10:56 PM
I'm still undecided on my best course of action but felt stripping the front end will have to be done anyway regardless.
#804
Posted 24 November 2012 - 11:17 PM
1) paint stripper
2) rust eater
3) prime & paint
Dont forget to clean the rusteater off completly
#805
Posted 24 November 2012 - 11:23 PM
Maybe you could:
1) paint stripper
2) rust eater
3) prime & paint
I think the rust thats showing will need more than that unfortunately. If you are stripping the front then Luke then maybe its time to bite the bullet and get the affected areas media blasted. The internal head light ring will need to come off mate i think as whatever you do there will still be rust behind it. Not what you want to hear i know but being brutally honest here.
#806
Posted 25 November 2012 - 12:02 AM
I'd need a new wing if I was to eradicate the rust completely?
#807
Posted 25 November 2012 - 12:31 AM
Hope that helps,
Pete
Edited by Petrol, 25 November 2012 - 12:53 AM.
#808
Posted 25 November 2012 - 12:52 AM
Also, looking through this thread from the start, the rust prevention that was done wasn't bad. Nothing that I wouldn't have done. But it wasn't done all over... Very open and shut case
#809
Posted 25 November 2012 - 08:56 AM
Maybe you could:
1) paint stripper
2) rust eater
3) prime & paint
I'd rather hear the honest truth mate! So I appreciate that. Determined not to do a half arsed job and be faced with the same issue later down the line.
First of all, I take my hat off to the painter for posting on here. I would also like to say that looking at the pictures of the job he did, well it was top notch and I would be more than happy for him to paint my shell. I'm a bit fussy with stuff like that. Like I said in an earlier post it seems to me that your problem is rust inside the seams. The only way to sort this is to split them. No amount of media blasting will sort it as it won't get in. I am not a believer of rust convertors and tend to go for rust removal chemicals and I think this will be your best bet. Have a look on the Bilt Hamber website.
Hope that helps,
Pete
Thank you Pete, I have no qualms about having the shell sprayed by him again in the future.
I can't split apart every seam though surely? & not everyone does that so how are their minis looking spotless?
If I create a strong enough barrier between the atmosphere & the inaccesible rust inside the seams then it won't have any access to moisture to spread, right?
What about acid dipping? Is that more thorough?
#810
Posted 25 November 2012 - 09:50 AM
Dipping the shell will be the best way, it will completely strip the paint and rust off. It seaps into all the seams though. Costs a fair bit, usually a waiting list and i'm not sure where around here canWhat about acid dipping? Is that more thorough?
Most of the cars looking shiney have new front panels (wings, front panel etc)
