My Mini ;) The Third Chapter. 998 Fast road.
842 replies to this topic
#676 carboy001
carboy001
  • 1,065 posts
Posted 02 August 2012 - 01:02 PM
Looking good Luke, your storming ahead!
Area you not putting down soundproofing and carpet before you put in the heater though?
#677 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 August 2012 - 05:26 PM
Looking great mate - cant wait for more updates :D
Ta mate! I'm off to another placement soon so the updates will slow again!
Finish mine when you have time Luke? I never get much time to work on Elliot of late :(.
Progress is looking good, so looking forward to when mine is eventually in paint.
Haha I'm struggling to find time to work on mine! Yeah I can't wait to see your in paint, the amount of detail & effort you've put into it, it'll look stunning.
For now I'm just going to slip the carpet up underneath until I iron out any possible problems, then I'll strip it all out and line the inside of the shell with soundproofing.
Another few hours in there today.. not many photos as it's just been a lot of electrical work and tidying up loose ends.
Lights on the centre binnacle are coming into play as well which is nice, I'd like to get it electrically sound and then continue on with the engine / brakes etc..
Also, on a centre binnacle.. which lights are supposed to flash to show the indicators are working..
I would've thought it should have been the orange lights either side.. but the middle green one at the top flashes.
Edited by analogue_radio, 02 August 2012 - 11:15 PM.
#678 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 02 August 2012 - 06:21 PM
Yeah it'll just be the single green light I would say.
I doubt mine will look anywhere near as good as yours. It'll be drivable again though so I can have the joy of a Mini in my life again.
#679 tedmcedd
tedmcedd
  • 2,751 posts
Posted 02 August 2012 - 06:44 PM
Long time no look!
Stunning. Just great!
Adam is right, green one in the centre flashes for both left and right hand indicators, orange is for oil pressure warning, red for ignition, and blue for high beam, there is one of the oranges spare, ive used it for fog light warning in the past...
#680 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 August 2012 - 08:03 PM
Thank you guys!
& okay that makes sense now, I just assumed as there were two orange lights on either side they would be for the indicators! At least it's wired up correctly.
I'm also after a MK1 gear knob & a MK1 choke cable.
#681 charie t
charie t
  • 3,153 posts
Posted 02 August 2012 - 08:54 PM
http://item.mobilewe...nid=47154042971
#682 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 August 2012 - 09:13 PM
Ah cheers Charlie, I had a look last week but they weren't as cheap as that one! That's sorted then.
#683 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2012 - 05:12 PM
Few more jobs done today!
More parts from Minispares.
New gear knob screwed into place, suits so much more than the other one I bought 2 years ago.
So that's for sale, brand new and unused (apart from being screwed on) £10 posted.
Headlamp rings on & looking super shiny!
Parts from the last update sprayed and dried.
I preferred how this Lucas coil clamp looks as opposed to the black one so I used that instead.
Steady in, I need to touch the bar up as the ratchet caught it & I know I'll have to undo that far end for the plate, but it's just a temporary thing.
Pretty cool to see!
New gear seal, gaiter & metal bush.
& I'm halfway with removing this damn stud to replace it with a new one.
#684 minimarco
minimarco
  • 1,950 posts
Posted 06 August 2012 - 05:24 PM
First time here, thoroughly impressed with the photography.
And a nice mini, love the color.
#685 grahama
grahama
  • 2,442 posts
Posted 06 August 2012 - 06:54 PM
Loving the progress, it reall looks good. One thing tho, the gearbox rod seal, should the metal bush with O ring be inside the box, not next to the rod as it is doing nothing there as far as I can see??? Might have got it wrong but just doesn't look right.
Graham
#686 charie t
charie t
  • 3,153 posts
Posted 06 August 2012 - 07:15 PM
Yupo G, its the wrong way luke
That silver collar should go before the seal in the gearbox.
Its a guide to stop the selector rod moving and abusing the seal.
#687 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2012 - 08:31 PM
Thank you mate!
Graham
Thank you guys and yeah I did realise that, I didn't replace the bush so I figured sticking the new one on that end would only compress the gaiter more and make it less prone to leaking & picking up dirt etc.. figured I'd paid for it so I might as well stick it on there somewhere, won't do any harm having another that end.
#688 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 06 August 2012 - 08:38 PM
Good idea!
#689 jaydee
jaydee
  • 8,565 posts
Posted 06 August 2012 - 08:50 PM
Thank you mate!
Graham
Mate it wont work that way, been there done that.
You wont be able to select 2nd and 4th and reverse, fit the big alloy o ring to the gearbox and slide the dust gaiter over.
#690 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2012 - 08:59 PM
Cheers for the heads up Jaydee, I'll make sure I change it when I'm next out.
