My Mini ;) The Third Chapter. 998 Fast road.
#586
Posted 07 April 2012 - 11:02 AM
It's looking great though, keep the updates coming.
#587
Posted 07 April 2012 - 01:25 PM
Stunning as usual, great attention to detail. Love the colour!
Thank you mate!
That's the way I did mine Luke. Just doesn't look quite right with just the rubber seal on top.
So you are saying the rubber is in the correct position, but the metal plate should sit on top, sandwiching the cable in-between?
Chris
Yeah I've sorted it now, looks better & makes a lot more sense!
Fantastic, I love it
Ta!
Mine had the seal sitting on top of the tunnel like yours, but with the small plate clamped on top of that to hold it down rather than underneath like you have done it.
Yeah I swapped it round this morning!
Right, got a morning and a few hours of the Afternoon in but I've got a family meal this afternoon so have had to cut the day short, but, got some more jobs done!
Sorted? I think so.
I've been given / asked for the wrong size reducer, so I need to ring Maniflow up and sort that.
Reducing some of the clutter in the garage by giving it a clean, refurbishing it if necessary and getting it ready to go on the shell.
I think I may need a new pedal box, might have one off the '90 that I can use.
Clean and ready to wire brush down. I am going to keep the pedals bare and use some grip tape.
Ku-rusted and left to dry.
Then I had a huuuge tidy up of the garage, that's it for today!
Will be out there tomorrow morning!
#588
Posted 07 April 2012 - 01:52 PM
#589
Posted 07 April 2012 - 03:13 PM
Oi! Thats my idea!
#590
Posted 07 April 2012 - 03:23 PM
You sure you don't fancy these;Clean and ready to wire brush down. I am going to keep the pedals bare and use some grip tape.
http://www.dsnclassi.../info_1155.html
with this;
http://www.dsnclassi.../info_1151.html
#591
Posted 07 April 2012 - 08:44 PM
That handbrake fairlead looks spot on now. I had a look at one at work today and that is the same as you have it now, so looking good. I had the same problem with the bolts on my pedal box. I centre punched the back of the heads and drilled them through to remove whats left of the old threaded part. Then used a flat chisel to break away the old heads (they're only spot welded at three points). Fitted 4 new hex head bolts and welded along two of the flats on each and job done, saved a good pedal box.
Yeah it makes an awful lot more sense this way.. the Moss diagram definitely has the metal plate underneath and upside down though.. odd.
I'll try and salvage this pedal box then, if I can't find the other.
Oi! Thats my idea!It will suit the car though!
Haha all credit due, yeah I think it will. It should feel a lot nicer under my feet as well, I've always fancied some Sparco racing shoes.. they'd be kept in my footwell so they'd keep the pedals nice and clean.. I'd have a shoebag in the boot for my normal shoes.. too much?!
with this;
Pfft won't even see them
This is a side note, but I'll be after a cheap car for this summer.. It needs to be something cool & retro, running & have it's MOT..
#592
Posted 08 April 2012 - 01:48 PM
And I found out this morning also that I'll be back working for BE Event Hire as soon as I'm finished with Uni, so aside from paying off the debts I've accumulated.. I'll have some money to throw at this thing and get it finished off.
Lick of paint on these items, will give them another, the other side of the petrol tanks now needs flipping, treating & painting.
Boots on! Really happy with how it's looking at the rear end.. tempted for either a Vinyl B&W numberplate.. or raised letters.
Fully secure and tightened, these were just in without washers whilst I was getting the whole thing in and lined up, so I've gone round today and added washers were there weren't and made sure it's all tightened up.
Again, washers added and tightened correctly.
(The doors ajar, that's why the gap looks big!)
Now I know the front subframe is fully in and secure, I can begin stripping apart and rebuilding the front suspension and running gear..
And that's where I left it for today! Off for another family meal.
I've got one more full day at home so tomorrow will be a big last push.
#593
Posted 08 April 2012 - 01:58 PM
stunning car
#594
Posted 08 April 2012 - 07:44 PM
The retro colour and the 10's really suit the car.
#595
Posted 09 April 2012 - 06:09 PM
I get far too much excitement reading your updates haha
stunning car
I have commented a couple of times on this project but im doing it again, progress looks excellent and i too get a bit too excited about updates, love the colour and love your attention to detail.
Cheers you two!
Flipped the tank over and coated the other side in Ku-rust.
Set about removing the running gear.
Removed, these were very rushed because I just wanted to get the whole thing rolling. I need to sort the shims and balljoints etc..
Affected the areas treated.
Same here.. I just went a bit mad.. figured it'll do more good than bad!
Dug out some parts to sort out. Found the pedal box from the '79, with the studs intact, yey!
I was going to re-tap the housing to fit my reverse switch, but instead I'll wire up a toggle switch and do it manually.
Gave the housing a clean.
& cleaned the inside, then re-packed with grease.
Cleaned the screw heads.
All in and tightened up.
Lovely & clean.
In position.
I painted this up before but I no longer think the green will suit, so I've masked it up ready to spray black.
Painted the tank us as the Ku-rust had dried.
Worked on splitting everything apart.
Done! Ku-rusted any bits as well after I took this photo.
And that's it for today! I'm back to Uni tomorrow to have an absolutely chaotic few weeks before Deadlines.. 6,500 words left to write of my Dissertation..
I'll hopefully come home for a weekend after my hand ins, so I aim to get the running gear / suspension back in and the engine dropped in.. hopefully!
Edited by analogue_radio, 09 April 2012 - 06:12 PM.
#596
Posted 09 April 2012 - 07:10 PM
#597
Posted 10 April 2012 - 11:48 PM
You'll know my cousins then?And I found out this morning also that I'll be back working for BE Event Hire as soon as I'm finished with Uni
#598
Posted 11 April 2012 - 08:53 AM
on a mission for sure,....looking good
Thank you mate!
Yeah I probably will, this will be my third summer there! Who are your cousins?
#599
Posted 13 April 2012 - 08:53 PM
Chris and Matt, be tempted at work there myselfYeah I probably will, this will be my third summer there! Who are your cousins?
#600
Posted 26 April 2012 - 05:11 PM
