My Mini ;) The Third Chapter. 998 Fast road.
#571
Posted 26 February 2012 - 08:02 PM
#572
Posted 11 March 2012 - 12:51 AM
#573
Posted 11 March 2012 - 06:35 PM
Drop bracket from JB Fabrication.
Snap off bolts.
Rubber replacements from Mini Sport.. hopefully these won't perish and split..
The steering rack went in the shell to the bodyshop so it's covered in dust & overspray.
Took it apart, gave it a clean and a polish.
Sat in the car
#574
Posted 26 March 2012 - 11:33 PM
#575
Posted 03 April 2012 - 06:25 PM
#576
Posted 04 April 2012 - 03:16 PM
#577
Posted 06 April 2012 - 06:47 PM
My custom made wing mirror mounts turned up, I made these out of cardboard and sent them off to a chap called 'C4NN0N' on here to be fabricated. Very impressed with them, means I'll be able to see out of the wing mirrors!
Next I replaced the rubbers that Mini Sport provided.. still look a state but at least the rubber isn't split anymore.
Then I spent the rest of the day on my back..
Handbrake guide in.
Greased up.
Got the front of the subframe fully secured & added my tow-hook.
Drilled holes, fiddled with grommets and roughly ran the cables.
They still need to be cut to length and secured, but I won't do that until I know what is going where.. the copper brake line will be bent over the tunnel underneath the seat and run down the furthest side with the fuel & battery lines.
Then I got her rear wheels on and dropped the back end down. First time I've see how it'll look with the arches on.. bloody gorgeous!
Will be out there again tomorrow morning!
#578
Posted 06 April 2012 - 06:59 PM
#579
#580
Posted 06 April 2012 - 07:09 PM
#581
Posted 06 April 2012 - 11:26 PM
http://www.minisport...au/prod1758.htm
http://www.somerford...page=page&id=61
http://www.ebay.co.u...=item33733fcce4
#582
Posted 06 April 2012 - 11:35 PM
& minifcd, I had a google and a search before I fitted it, but like you, I couldn't find a definite answer! It was unclear on the blow apart diagrams as to which side of the bodywork things should sit, so I just figured that the way I've done it now means the rubber is offering protection from the cable rubbing against the bodywork and the metal shroud underneath just offers a little more protection from the elements and acts as a loose guide.
Looking at those links above, they all seem to come with 2 rubbers & 2 metal guides.. where as mine only came with 1 of each.
So you are saying the rubber is in the correct position, but the metal plate should sit on top, sandwiching the cable in-between?
#583
Posted 06 April 2012 - 11:39 PM
#584
Posted 07 April 2012 - 10:28 AM
That's the way I did mine Luke. Just doesn't look quite right with just the rubber seal on top.So you are saying the rubber is in the correct position, but the metal plate should sit on top, sandwiching the cable in-between?
Chris
#585
Posted 07 April 2012 - 11:00 AM
