Yeah it looks like a MK2 switch panel
I've also got a MK1 switch panel but that was too small and wouldn't have worked in the same way. But yep, that's the idea
Right.. huuuuge update.. 2 days worth! and you all know I like taking photos.
Various orders. Also popped in at Mini Spares in Birmingham whilst we were near there picking up Dads re-chromed bits for his Norton.
Seam strips on, bar the front O/S as that a-panel is being replaced.
New top arms and the pins I was going to use on the old arms.
In! lovely.
These are brand new and unused, so if anyone wants just the bearings, PM me.
Hubs built back up and greased, they need shimming properly but for now just to get it rolling they'll do.
One door on! and the gaps aren't bad, that's with 3mm of shims. Don't forget that a-panel is being replaced so that'll straighten up.
Loosely assembled and ready to go in.
Arms and bump stops in, for some reason the screws I had ordered from Moss were far too short so I had a dig around and found these bolts.
The donuts are also in, but just suspended with zip ties.
Back end dropped down
Genius bonnet stay device.
Subframe up and in!
Keeping parts protected and clean.
Subframe rear mounts sort of in.. the bolts are too short so I've had to order some longer ones from Ebay.
