My Mini ;) The Third Chapter. 998 Fast road.
#346
Posted 31 August 2011 - 08:20 PM
#347
Posted 31 August 2011 - 08:23 PM
#348
Posted 31 August 2011 - 10:18 PM
I had to do the same with my front panel as the extra material looked daft!
#349
Posted 01 September 2011 - 05:13 PM
you seem to have had to repair alot of previous owners shoddy repairs,
#350
Posted 01 September 2011 - 05:21 PM
#351
Posted 01 September 2011 - 07:19 PM
If you measure how big the lip is on the edge of the arch and then scribe a line on the valance. Then just use a cutting disk to cut near the line and finish up with a linishing pad up to the line, jobs a good en!
I'll see what I can do this Saturday when I can get a full day in there.
the previous owner had fitted a new rear valance
Yup!
love your work man
Another job done-ish tonight.. need to order yet more fixings from Moss!
& still no packages from Mini Sport or Moss.. really hoping they will come tomorrow so I can get on with it on Saturday, still, plenty of other things on the to do list I can get cracking with!
The old handbrake from my '90, some wire wool & paint stripper might make things look nicer again! but it'll do for now.
Zip ties are temporary as well
Needs greasing up, but won't do that until everything is in and set.
Again, will grease.
& need to order the parts.
#352
Posted 02 September 2011 - 08:08 PM
What's the tab on the right hand side for?
& what is this..?
As you can see it's all just a bit of bubbly surface rust which is nice! I need to take the spot welds out to remove the lip as well.
Sits amazingly well compared to that daft FG bonnet I had.. needs some fettling mind and once the lip is removed it'll sit differently, but just having it placed in as lifted my spirits about the situation.
The hinges & door lock mechanism I had ordered as well.
Cleaned up!
Wired brushed them down to remove any flakey rust.
& Ku-rusted..
I was going to start on my bonnet but it was getting late and I didn't fancy disturbing the neighbours!
#353
Posted 02 September 2011 - 08:40 PM
Ive been trying to work out what that tab is for, as it's on my spare bonnet and dont know wether to take it off or not.
I think the thing on the far right is for the bonnet hook/ catch (hooks on the slam panel)?, but on mine instead of being on the right its in the center
#355
Posted 02 September 2011 - 09:04 PM
#356
Posted 02 September 2011 - 10:24 PM
The tab on the other side is where the bonnet stay attaches.
The thing in the middle, not a clue! Haha.
Looks a pretty good condition bonnet though, how much did it set you back?
#357
Posted 02 September 2011 - 10:40 PM
Only £35!
I'll try and find out what year & model it's off to identify the unknown part.
#358
Posted 02 September 2011 - 11:03 PM
Not bad at all!
Yeah that bit in the middle is quite confusing. I can't make my mind up if it looks standard or not.
#359
Posted 03 September 2011 - 01:59 PM
sorry to bud in, just check that the previous owner has spot/tack welded close enough to the rear panel and you do not cut through them.If you measure how big the lip is on the edge of the arch and then scribe a line on the valance. Then just use a cutting disk to cut near the line and finish up with a linishing pad up to the line, jobs a good en!
#360
Posted 03 September 2011 - 03:20 PM
Still, had a few things to get on with but have had to cut the day short.
Hinges are etched.
Bonnet is now 'MK1'
Attacked any bubbly areas and gave it a good licking of Ku-Rust.
Figured out which are fronts and which are rears.
Rubber beading cut to size (left 5mm bigger on each strip to give some room for adjustment when they properly go on)
Working out where I will be cutting the slits to sit around the seams.
That's all for today, should be getting back from my Girlfriends afternoon-ish so can get an evening in the garage.
Bing (1)
