My Mini ;) The Third Chapter. 998 Fast road.
842 replies to this topic
#271 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 02 August 2011 - 05:23 PM
in youre last post picture 2nd to last you can see the panel isnt correct as it has a kink in it
That's the before photo if I read right
#272 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 August 2011 - 05:27 PM
Why red oxide over normal grey or zinc primer? Just trust it from past expierance?
Well I'm bare metalling areas and then using a dusting of etch, so the red oxide covers this. It's an extra layer of protection as well :)
Yep that's the before photo before I pulled it out a bit :D
#273 LouisT
LouisT
  • 197 posts
Posted 02 August 2011 - 06:39 PM
Loving the progress bud!!
Shame about the front panel but shouldn't be too hard to get right.
i came across a couple of pictures the other day and thought you may like them ( i do) in regards to the colour etc.
Louis
  • Attached File  ar.jpg   26.95K   41 downloads
  • Attached File  ar2.jpg   24.51K   47 downloads
Edited by LouisT, 02 August 2011 - 06:40 PM.
#274 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 August 2011 - 06:34 AM
Yeah it's not far off! I'm going to MITP so will pick up a bonnet there.
Ooo that is nice!
#275 analogue_radio
analogue_radio
  • 4,897 posts
Posted 05 August 2011 - 08:01 PM
Small updateeeee.
Mum lent her upholstery skills and helped start me off with covering the door cards, which I need to finish when I get time.
Annnnd since I drilled the holes for the wing mirrors, I really haven't been happy with the situation.. I won't be able to see out of them, I'll struggle to get the nuts and washers on and I'm almost certain that the thread will foul on the window when wound down! so overall not a good way to leave things..
A friend uploaded a photo of a Swiftune mini and I noticed how the wing mirrors were mounted, sorted!
(this isn't the photo he uploaded, but it shows it better)
I had a quick play with some cardboard, it obviously needs some more attention to detail and the top needs widening by roughly 2cm, but the principle is there! I'll either make it myself or find someone to fabricate it for me and it'll be made from brushed aluminium, 1mm thickness should do the trick.
Also had to order some longer eye bolts to fit through the harness bar as the ones supplied with the harness weren't long enough. They are zinc plated so a different colour :closed: but oh well, if I come across some the same colour as the originals then I'll replace them, or visa versa! just as long as they all match.
Edited by analogue_radio, 05 August 2011 - 08:02 PM.
#276 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2011 - 05:15 PM
Stressful day in the garage, got a fair bit done though.. albeit heavy handily.
Getting myself set up for welding. It was a horrible uncomfortable squeeze to get my head and welding helmet up into the wheel arch.. If I was experienced I'd quickly whip the wings and a-panels off to sort the rust out underneath, but I can't!
So say hello to my horrible looking welding.. but again, it'll do the job! I'll get a good load of seam sealer and underseal up there to make sure it's all sealed and protected.
Then I moved onto the rear subframe, I needed to get this up and mounted so I can turn it into a rolling shell. Wasn't sure whether I should assemble it on the floor and then lift it into position, but then I remembered how heavy and awkward that would be. So I lay on my back and 'benchpressed' the subframe upwards whilst Dad quickly put all the nuts and bolts in.
Once that was in I went around removing a bolt at a time to apply copper grease and then put the bolt back in and moved onto the next one.
So that's the subframe in and tightened up, happy with that.
A lot of muttered curse words from me later.. Dad and I had lifted and fitted everything into place, there are a few bits missing and I'd like to go around to double check my torques & apply copper grease etc.. but the difficult work is done.. just needs to be repeated on the other side :o
I will also mask everything off and give the arches another coat of underseal as you can see where it's been scuffed. I'll also get a small paintbrush out and touch up the radius arm, subframe & brake backing plate with some black hammerite to tidy the area up.
And then I put my wheel on :w00t: :thumbsup:
I think I'd be trying my luck if I ran without arches.. but they look so damn nice! They'll look even nicer with the GB caps on and when it's sat on the floor and sitting at the correct low height.
#277 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 06 August 2011 - 09:34 PM
I wouldn't try yor luck Luke, they're blatently illegal and you only need one Police man who's had a bad day and you're looking at points and a fine.
I thought your GB's were 10x6?
#278 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2011 - 09:36 PM
Yeah they are 10x6 :thumbsup: & I've got some W&P arches in the garage waiting to go on :o
#279 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 06 August 2011 - 09:41 PM
I expected them to stick out more, they look they they stick out about the same as my Exactons.
Mmmmm W&P are lovely. If I find special arches don't cover mine enough I'll be getting the same. They flow with the car so nicely.
#280 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 August 2011 - 09:48 PM
They may do more when it's sat on the ground and the wheel is closer to the bodywork.
Yup they are :D
Tomorrow I plan on doing what I've done today on the N/S.
#281 Midas Mk1
Midas Mk1
  • 5,775 posts
  • Local Club: S.U.N.M.C
Posted 06 August 2011 - 10:51 PM
Looking Great! I'd be tempted to go archless to be honest! :D
#282 analogue_radio
analogue_radio
  • 4,897 posts
Posted 07 August 2011 - 08:55 AM
Problem with doing that is that if I were to get caught out I don't fancy having points & a fine!
Plus I'd need to get the arches mounted up as they will be sprayed body colour, so something that needs to be done before it gets sent away for paint!
#283 LouisT
LouisT
  • 197 posts
Posted 07 August 2011 - 10:22 AM
getting there mate, wish mine was as far on as yours!!!
i need to get a move on really, few things to buy at mitp,
bet you have a long list too don't you?
Louis
#284 analogue_radio
analogue_radio
  • 4,897 posts
Posted 07 August 2011 - 11:30 AM
I should've been at this stage long ago! :) summer is flying by though!
Well.. yes and no! I don't have much left to do until the shell is ready for paint.. it's just fiddly bits here and there.
This morning I've dropped the rear subframe back out and I'm going round the shell tidying up the bodywork, blobs of weld here and there etc..
I'll be going to MITP as well :D need to get a list of things together to buy.
#285 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 07 August 2011 - 12:15 PM
Nice project! An inspirational retro build. :D
