My Mini ;) The Third Chapter. 998 Fast road.
842 replies to this topic
#241 analogue_radio
analogue_radio
  • 4,897 posts
Posted 11 July 2011 - 06:25 PM
Yep! It was only a few quid so I thought it was a wise buy, not the most retro looking of things and I hopefully won't be using it! good for reassurance though.
#242 analogue_radio
analogue_radio
  • 4,897 posts
Posted 12 July 2011 - 07:30 PM
Had an hour or two in the garage after work, cut out the weak section of metal on the rear quarter and made a repair patch.. but then dropped it and it slid between the closing panel and down into the sill.. so started to make another one and then somehow slipped with the angle grinder and cut vertically into the top of my index finger with the 1mm cutting disc.. that caused me to throw the angle grinder on the floor in shock & I broke the disc in doing so!
Good session :D
#243 analogue_radio
analogue_radio
  • 4,897 posts
Posted 21 July 2011 - 07:46 PM
Riiiight..
I'm back from a weekend in Norfolk with the missus and a week in Iceland for a family wedding! That's my summer holidays over and done with so now it's just the very rapid up and coming date of going back to Uni that stands before me..
Came back to find a few parcels :)
Overtaking mirror I bought off here, it's stainless steel :) can't be doing with Chrome anymore, too shiny and prone to rust/white specks.
Works rally style dashboard :P so stoked with this.
& copper plate, not really worth a photo :) but it'll help me (hopefully) do the air vent repairs.
Also got a plate made for the rear 1/4 tonight
Welded
Ground and covered in filler
I've left it to dry and I'll finish it off the next time I'm out there
Really will make a push to get it done now :) hardly any welding left.
Oh and I'm also opting for a metal bonnet rather than my fibreglass one.. few valid reasons.. It fits awfully & even with fettling I won't be happy with it, I'm not keen on having visible fixings in each corner, It will take too long to get into.. and if I need to get into the bonnet in a hurry (fire) then I'd rather get in there quickly, when I take the bonnet off I won't have anywhere to place it down and I don't want to risk chipping the paint and lastly I'm not concerned about saving weight so that factor doesn't bother me.
I'm picking up at bonnet from MITP for £40 and the fibreglass one cost me £70+, so I'm not loosing money by deciding to change.
#244 izzy
izzy
  • 190 posts
Posted 22 July 2011 - 10:44 AM
whats the OMP thing?
harness/seat belt cutter :)
thanks
#245 analogue_radio
analogue_radio
  • 4,897 posts
Posted 24 July 2011 - 09:32 PM
Update from yesterday..
:P
Nice and convex as well!
& the whole lot :D
Rear 1/4 sanded down.. needs some more work doing to it to get it 100% smooth and unnoticeable, but I might leave that to the professionals at the bodyshop.
Then I needed to get the rear bumper sitting straight and level which meant redrilling one of the holes.
Done! Sits a lot more nicer now.
Also marked them up so I know which is which, in case some of the bolts are at different angles causing them to sit different etc..
And seeing as that's almost all the bodywork niggles sorted out on the rear half.. I decided to now dive in at the deep end and sort the last problematic area out..
O/S area..
Then with the dremel I opened up the area removing all the weak surrounding metal meaning I can now start to make a small patch and get it welded in.
I also did the same with the N/S side but the photos won't upload! It looks a lot worse though.. and even more tricky.. hmm..
Edited by analogue_radio, 25 July 2011 - 04:44 PM.
#246 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 July 2011 - 07:24 PM
Looking good Luke!
Weird you had to do that with the bumper mountings though although it does look like the stud must be miles out. To get my front to fit close it took alot of pulling (nearly pulled Elliot off the axle stands :thumbsup:).
Your dash setup is looking similar to how I want mine. But I want my boxes in brushed aluminium. Think I'm probably going to have to make them up myself, not seen anywhere that does them!
Keep it up!
#247 analogue_radio
analogue_radio
  • 4,897 posts
Posted 25 July 2011 - 07:31 PM
Cheers Adam! well yeah the front is perfect, but I know Shifty replaced the rear valance.. so.. who knows.. but it's sorted now.
I'm currently working on repairing the O/S air vent.. god knows why a new wing was put on without sorting the rust up there, but I'm trying my best to correct it. I've done some welding tonight and I've just thrown a load of Ku-Rust up there to kill any remaining rust before welding in another patch.
After I've done all that the whole thing will be smothered in red oxide, seam sealer & underseal.
P.s. I don't think they are hard to make up! If you find a template from somewhere it's just a few folds here and there.
#248 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 July 2011 - 11:09 PM
Ahh I see, did he drill the new holes? You might want to check your bootlid hinges still fit as that bumper does look damn close. Looks awesome though.
Sometimes you just miss these little bits of rust, I know as I've done it haha.
Yeah, I'll either find a template online or make one using some cardboard. I was thinking if I folded it so the front was perfectly flat and then have some external overlaps on the sides all riveted up. It'd look very aircrafty (technical term there). Not sure what I'll end up putting in them. At the moment I only have a rev counter for the driver side one and my head unit will go in the passenger side one along with a dock for an external HD to plug in to the head unit.
Might even be overkill having the dash boxes with so few things in them? What have you got to go in yours?
#249 bcjames
bcjames
  • 2,728 posts
Posted 26 July 2011 - 12:30 PM
The projects looking awesome! Getting so much closer to paint! My rear bumping is a fair bit out too, going by the holes. Pulling the bumper really hard got it in, but I've probably wrecked the thread on that stud doing so. I should have just got the drill/file out!
Random, but I really like your garage doors!
-James
#250 analogue_radio
analogue_radio
  • 4,897 posts
Posted 26 July 2011 - 04:21 PM
Ah true.. well if it's a tight fit I can get the dremel out and extend the holes away from the shell, to allow for more room.
Well on the right hand side I'm planning on putting the turbo, clock & ammeter etc.. I've got a few others as well. Annnd also lots of toggle switches for various things, might even put in a few blank ones just for the aesthetics.
And on the left hand side I've got a map light, some retro pen holders, I want to wire my fuse box there as well.. just bits and bobs! accessories etc..
-James
Haha hasty :thumbsup: cheers though!
& cheers for the compliment on the garage doors, I'll pass it on to my Dad :shifty:
#251 analogue_radio
analogue_radio
  • 4,897 posts
Posted 26 July 2011 - 04:32 PM
Here you go Adam, I posted this a while ago but just to give you some food for thought.
Gauges
- Speedo
- Fuel
- Oil temp
- Amp
- Boost
- R.P.M
Accessories
- Map light
- Cigarette lighter (for GPS etc..)
- Pen holder (need to get)
- Clock (need to get)
Switches/electrics
- Fuse box? (might run the wiring inside the cab, hidden)
- Various toggle switches and switch extensions (unsure what is what at the moment)
- Battery Cut Off
& everything will be labelled up with my old Dymo.
#252 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 July 2011 - 07:32 PM
Ah awesome! Much more planned than me then :shifty:. What is the gold thing on the bottom left?
I might wait until I have a need of more gauges to do mine and just make up some tidy brackets to hold my head unit and rev counter.
I want to go turbo at some point over the next year so then I'll need more room for gauges hehe.
#253 analogue_radio
analogue_radio
  • 4,897 posts
Posted 30 July 2011 - 07:35 PM
Ah awesome! Much more planned than me then :P. What is the gold thing on the bottom left?
That's my Dymo lablemaker ;) It's one of the old ones though because they produce the raised letters, as opposed to the newer ones which are just printed ink.
Had a good afternoon today ;)
First of all was a trip to Tanvic to get my tires fitted!
£10 a corner and £2 for the disposal of each tire.. the going rate I think. They need a good scrub and the residue removing from the weights, but it's another job done :thumbsup: Oh and I need to pick up another tire for the spare, but I'm in no hurry for that.
Then Dad and I had a much needed tidy up, the Lambretta was moved to the other garage and boxes of Motorbike parts moved to where the Lambretta was. This is because he's expecting parts back from being refurbished and painted so hopefully the Norton will start to be put back together soon.
& I found the biggest spider ever :o
Tidy-er ;)
Got the front up on a wooden work horse to make the whole thing level, it will also make it easier when I'm up inside the arches sorting those patches out.
Then my aim was to sort the rear out and get everything sitting correct. Boot sat in the position with the rubber seal in place.
Got the catch fastened in place so it shuts and locks :)
Hinges on as well :)
Then I wanted to get the Reverse & Fog lights mounted up.. I prefer the position where they sit further apart, if they are too close it'll give the impression that the rear end is fat and squished.
And the brackets I made. This is how they will be mounted, I'll weld the underside. I'll then drill a hole in the rear valance and then through the boot floor so the wires can feed up, they'll all be kept nice and tight so they won't be visible.
#254 analogue_radio
analogue_radio
  • 4,897 posts
Posted 31 July 2011 - 06:57 PM
Another wonderfully productive day :mrcool:
Out of focus!
Both sides tacked on, just to make sure they both sit the same distance apart etc..
I then seam welded the underside and shaped down the excess unneeded metal.
Then I drilled holes through the rear valance and boot floor (both NS and OS of course) and fitted rubber grommets, the wires won't be visible as they are tucked nice and high.
Hoovered the boot out and gave it some etch primer.
And finished off with red oxide. Not a bad job I don't think :tumble:
And then went on a huge cleaning spree with the hoover (I wore ear defenders for this part as I can't stand the noise.) The shell was covered in red dust from the red oxide and bits of metal from grinding etc.. so that's all looking a lot nicer and cleaner now.
Mounted up my Cobra Classics.. bit of a fiddle but got there in the end.
:mrcool: :mrcool: :mrcool: :mrcool:
Harnesses in to make sure it all sits nicely.
Couldn't resist!
All the straps need adjusting and tightening up, but you get the idea :huh:
And the eyelets fit nicely into the existing seat belt holes.
Harness bar level (this will be sprayed body colour)
One side drilled and the backing plates on.
Edited by analogue_radio, 31 July 2011 - 06:59 PM.
#255 analogue_radio
analogue_radio
  • 4,897 posts
Posted 31 July 2011 - 06:59 PM
OS needed some fettling, operator error!
After enlarging one of the holes, done!
Etched.
Red oxide'd.
& gave the wheel arches another coat of underseal to finish it all off nicely.
I've also got these 2 items for sale, so check out my for sale thread.. here.
Going to sit and write a list of what jobs are left to do.. not much :tumble:
