My Mini ;) The Third Chapter. 998 Fast road.
#211
Posted 26 June 2011 - 09:01 PM
Welded & filled the unused grille holes.
Sanded and smoooooth.
Etched and then red oxide'd, lovely!
These stripes had to go, so out came the wallpaper heat gun and a scraper..
Gone.
After sanding and red oxidising.. still some rough left.. any suggestions? might just let the bodyshop take care of it.
This hole was left behind..
Gone.
And the whole door step tidied and finished off.
Few rough areas on the N/S rear quarter.
And another..
And one more..
Welded the other two up but this one blew through and was a bit thin, so I took it back with the knotted wire wheel. I'll patch it a night this week.
I then started to weld up the air vents.. but..
The flap disc decided to commit suicide and kick back into my hand. Yes that's a blood.. I know I'm lucky to be alive! It was more of an impact thing rather than taking my skin off, felt like I had broken a finger again when it hit me.
Tidied the garage and had a quick play with this
I've got underseal, black hammerite, flap discs and black suede on their way.
The harnesses should be turning up tomorrow.
And I've got a big order to place with either Mini Spares or Mini Sport.. depends who has got what in stock.
It's getting there
#212
Posted 26 June 2011 - 09:09 PM
CFACEBOOK2500
10% off
Coming along a treat! It's making me look at Elliot and wish a few bits of her were a bit more straight .
#213
Posted 26 June 2011 - 09:15 PM
Lovely!
Does that stack on top of the TMF+ discount though?
Don't be daft, Elliot looks brilliant!
#214
Posted 26 June 2011 - 09:36 PM
Nah it doesn't sadly. That's still another 2.5% though, not to be poked at!
Lovely!
It's the bottoms of the rear quaters that annoy me, I was eager with my welding and they're gonna take some filler to look right. Repairs are solid though so they'll last fine.
#215
Posted 26 June 2011 - 09:58 PM
Ah just had a quick look and I see where you mean, but still, at least they are welded nicely and sound! Just take some time fillering and sanding
#216
Posted 26 June 2011 - 11:09 PM
Threw a very quick coat of this stuff on the OS boot underside, yes it's thin in places and patchy but it was dark and I need to pick up a few more cans of the stuff, so it will be revisited
if you use the hammerite stone chip it goes on smooth and isn't tacky, would be easier to clean off
any road dirt ( can also be painted over ) ...
heres a pic of Ratty's arch
#217
Posted 26 June 2011 - 11:30 PM
#218
Posted 27 June 2011 - 06:26 AM
Cheers Craig!
#219
Posted 27 June 2011 - 02:36 PM
#220
Posted 27 June 2011 - 03:37 PM
I love your attention to detail! I wish I had the time to do things as properly as you do!
#221
Posted 29 June 2011 - 07:10 PM
Quick update as I'm back for the weekend but I'm going to Berlin until Monday, so I won't be making any progress but it meant I could open all the packages that had arrived over the past few weeks.
From Minispares -
- MK1 grille package, opted for the one with the dipped slat for the external bonnet release even though I'm not fitting one, just to make it look a bit more subtle
- Pair of boot hinges, so I can drill holes in the fibreglass MK1 boot
- Headgasket, so I can get on with the engine whilst the shell is away for paint
From Demon Tweeks -
- OMP Bonnet pins, for location and drilling holes
- Spring hooks, same reason
Ebay
Arc Angels
- MK1 ultralite bonnet.
Will update with photos soon.
Edited by lulu85ritz, 29 June 2011 - 07:33 PM.
#222
Posted 29 June 2011 - 07:15 PM
#223
Posted 29 June 2011 - 07:36 PM
#224
Posted 02 July 2011 - 05:48 PM
New stufff
Lovely!
Radius arms needed some more paint
Painted up
Don't put your cup of tea next to your tin of paint..
Both sides done.
My Dad was sorting his car so I thought I'd compare wheel sizes
After more underseal.. really tricky to see the thin areas, so after I took this I went back and gave it all another coat. Happy I've got it all now.
Rear subframe was suffering from the same problem..
Sorted.
Gaydon tomorrow! Got a few parts in mind to pick up!
#225
Posted 02 July 2011 - 07:53 PM
Graham
