Getting hardly any time now I'm working
So yesterday was more tidying and welding.
I couldn't leave these alone.. last thing I wanted was water to sit and sink into these holes, so I welded them all up and tidied up the area.
Welded, ground and etched.
Coated in red oxide.
Welded up the wing mirror holes. Heavily considering buying these..
I saw them at the National Street Rod Association show, really nice brushed aluminium finish and they are very light weight.
Needed some attention, another hole..
Looking through the flitch panel.. made me laugh! How could you leave that and be happy with it.. the water and mud will just get into it straight away and cause problems!
That area was welded and then Ku-rusted.
Etched.
Red oxide.
Before I did all this I got Dad to lift the rear end up which meant I could slide the wooden horse further under, thus giving me access to the full rear end.. meaning I could then seam seal, underseal and then attach the rear subframe.
And I warn you.. the following image isn't pretty.
What a mess!
BUT.. there is a good layer of protection now, it's all out of sight and it will be covered with underseal
I need to get this lot out and sort the paint out on the arms, they were a reconditioned set from Mini Spares I think.. or maybe somewhere else. What paint would you recommend? I'll take them apart again so hoping to use an aerosol.
