My Mini ;) The Third Chapter. 998 Fast road.
842 replies to this topic
#151 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 May 2011 - 07:50 AM
Yeah could do that, or use stepped washers which would be a bit easier and cheaper! But they are both quick solutions.
Also got a few billet alloy parts bookmarked from DSN classics for the engine :shifty:
#152 tedmcedd
tedmcedd
  • 2,751 posts
Posted 02 May 2011 - 12:46 PM
engine looks nice man, i had to grind down my inlet once, easiest way!
shiney parts are always nice!
Ed
#153 analogue_radio
analogue_radio
  • 4,897 posts
Posted 02 May 2011 - 03:40 PM
Headed back to Uni tonight so no time during the day to get into the garage, although I played and laid out how my dashboard is starting to look.
Gauges
- Speedo
- Fuel
- Oil temp
- Amp
- Boost
- R.P.M
Accessories
- Map light
- Cigarette lighter (for GPS etc..)
- Pen holder (need to get)
- Clock (need to get)
Switches/electrics
- Fuse box? (might run the wiring inside the cab, hidden)
- Various toggle switches and switch extensions (unsure what is what at the moment)
- Battery Cut Off
& everything will be labelled up with my old Dymo.
Edited by analogue_radio, 03 May 2011 - 12:06 AM.
#154 analogue_radio
analogue_radio
  • 4,897 posts
Posted 09 May 2011 - 12:11 PM
I'll be home tonight for a few days :D can't be doing with wasting days here waiting for my end of year reviews.
Also decided to run Megajolt, so that's something I'm learning about at the moment.
#155 analogue_radio
analogue_radio
  • 4,897 posts
Posted 10 May 2011 - 04:14 PM
Small afternoon update.. I've been out with my Grandpa collecting something :) you'll see..
Some more gas.
Dizzy drive removed, will be running Megajolt so it can be plugged.
Carb manifold grinded, angle grinder and then the file where the angle grinder couldn't reach, it all sits flush now.
And then I ran into a few problems regarding the T2 turbo fitment so that got ironed out on TM, and in the meantime I popped across to Grandmas with my Grandpa to pick up..
Project page for that HERE.
#156 SomethingNew71
SomethingNew71
  • 453 posts
  • Local Club: Carolinas Classic Minis United
Posted 10 May 2011 - 04:20 PM
Some more gas.
Oh my goodness. That poor Vespa. How could it get that far gone, it's just crazy to me.
#157 analogue_radio
analogue_radio
  • 4,897 posts
Posted 10 May 2011 - 04:22 PM
It's a Lambretta! :) keep the chat in that project page matey ;)
But cheers so much for removing the pictures when you quoted! makes a nice change.
#158 SomethingNew71
SomethingNew71
  • 453 posts
Posted 10 May 2011 - 04:26 PM
It's a Lambretta! ;) keep the chat in that project page matey :)
Ahh yes it is isn't it! Haha! I just started tracking it there. :)
#159 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 May 2011 - 04:37 PM
:) ive worked on them lambas before ;) very nice when there done
and cars looking good dude :)
#160 analogue_radio
analogue_radio
  • 4,897 posts
Posted 10 May 2011 - 06:55 PM
Another little update,
Shock mount welded and ground as flat as possible.
FULL day tomorrow so I will be tidying up that top half of the underside, ready to roll it so I can deal with the same rusty patches on the lower side. If that makes sense :)
#161 animammel
animammel
  • 167 posts
Posted 10 May 2011 - 07:29 PM
my father restored a Lambretta with his father many years ago, still got the picture. Good luck with that, good to see you working with two wheels as well
#162 analogue_radio
analogue_radio
  • 4,897 posts
Posted 11 May 2011 - 06:24 PM
Update!
Had a struggle with the Turbo today as well, but that\'s something I\'ll carry on with when the shell is away being sprayed.
Wire brushed and then cleaned with a petrol soaked rag.
I don\'t know what the best course of action is.. I could get a welder up there but not an angle grinder easily.. and I won\'t be using the fresh air vents.
Straightened.
And then this.. come on.. why would you leave it like that?!
Corrected.
And then took the rear mount off (I had to weld some tear holes here because I was a bit lazy and didn\'t drill the spot welds out.. whoops) which I believe aren\'t jacking points but are the factory fitted mounts for when the shell was being moved around the production line.
Ku-rusted and then etched of course.
Got the doors out, the drivers side is off the 1979 and the passenger side is one I bought.
I got them both 99% stripped down and cleaned up (rounded door hinge bolt to drill out on the \'79 door) of course I\'ve got a MK1 fibreglass boot and bonnet so they are both ready.
Drivers side before..
And after! >_<
And then the underside got a good coating of Red Oxide! about 4 cans worth I think! Looking so good now, chuffed! :thumbsup:
Edited by analogue_radio, 11 May 2011 - 07:51 PM.
#163 analogue_radio
analogue_radio
  • 4,897 posts
Posted 12 May 2011 - 05:42 PM
Another update, back to Uni tonight for my final review tomorrow and then I'll be home for summer this weekend! :P
Rolled onto a wooden workhorse covered in a dust sheet, got to keep my freshly red oxide'd surfaces clean! :)
Door step.
Chopped a small section out of an unused bit of floorpan.
So welded that up, and then added a bit at the back to weld.
After a bit of welding, grinding and filler later. Nice and smooth :(
Shifty had done some welding in this corner and fillered over it, but hadn't smoothed it all out. So I finished that and then coated in red oxide.
Rear window was a bit gammy, it was covered in a sticky residue from the headlining. So I cleaned all that off and etched.
Coated in red oxide around the window lip inside and out.
Then the postman FINALLY turned up with a small package from DSN.
Stud in and torqued down.
Everything on. Dizzy plug looks niiiiiice! was thinking about going red.. but glad I went with silver.
Unused wiper and arial holes were next..
After some welding, grinding, filler and etch.. ta da! just about smooth.
I probably should have checked and not just guessed which holes were unused :) could've been something to regret.
#164 llawwehttam
llawwehttam
    Just On Tickover
  • 6 posts
  • Local Club: Not yet.
Posted 12 May 2011 - 06:22 PM
Wowza! This is looking good. It always impresses me when people work on a car, which is a pretty messy job, but always make it look clean and tidy..... maybe its just good photography :P. Either way I admire your attention to detail.
#165 analogue_radio
analogue_radio
  • 4,897 posts
Posted 13 May 2011 - 12:49 AM
Come a far way since that messy stage!
Still need to roll the shell over and bare metal the front and rear arches on the passenger side though and do the welding. It will get messy again then :thumbsup:
