Frumpy Gets Some Love
#451
Posted 22 January 2014 - 07:56 PM
I'd definitely reccommend Steve for any engine work, was surprised when he phoned one night to ask what cam I'm using, just for him to get the right poundage of valve springs!! Service doesn't get much better
#452
Posted 24 January 2014 - 07:43 PM
a fiat rad?!? will be using that on the racer, cant really afford to smash up a 300 quid ally caterham rad i was planning on using! cheers:P
that head looks like its been worked propper, this engines going to fly!
#453
Posted 24 January 2014 - 08:23 PM
Wow this is coming along well! Looking really good man!
#454
Posted 24 January 2014 - 08:34 PM
Still plenty of room for work on the head, valves are standard size for now. Didn't see much point in a race head for a 998!!
Cheers leaky! Hopefully the engine will be bolted together tomorrow then once I get some bits from Bingley, Sunday I may even be able to give it a test fire (don't hold me to that!!!)
#455
Posted 27 January 2014 - 08:39 PM
DSN certainly saw me coming and swiftly emptied my pockets, not that I will complain.
Most just engine brackets/bolts but things that's needed all the same. Also picked up a set of they're alloy door hinges which should loose me some more weight off the doors.
Had placed an order with arc angels for a 2 piece front end and a set of group 5 arches, so collected them yesterday. I'm a little disappointed with the bonnet as the curves are all wrong, but I will drop them a call tomorrow and see if they're anything that an be done.
Also bought new headlamp assemblies for the front end. So have built them up ready to throw them on to mock up
Finally bought myself a high torque started aswell, more so to help with clearance against my radiator than anything else.
#456
Posted 28 January 2014 - 09:30 PM
what starter is that? i need to invest!
#457
Posted 01 February 2014 - 06:38 PM
Fitted my oil cooler today, realised the generic cooler hoses won't fit how I want, so ive had to order up a load of AN fittings and hose for it. Should look the part aswell though
#458
Posted 01 February 2014 - 06:58 PM
This is really coming along.
I I feel you pain with the AN fittings, I went through the JJC site adding up all the fittings I wanted and then had a heart attack.
Edited by Tupers, 01 February 2014 - 06:59 PM.
#459
Posted 02 February 2014 - 11:49 AM
slowly slowly catchy monkey!!
haha fittings... oooh we love fittings... im lucky we were putting a large order of them in for a car build i was doing at work, got a hella discount:D so now everything on the miglia is aeroquip XD
#460
Posted 02 February 2014 - 08:01 PM
Welcome to try my hoses.
#461
Posted 02 February 2014 - 08:44 PM
The hoses I bought from minispeed fit, but they interfere with the placement of the radiator
I've just ordered a load of goodridge push fit oil hose and fittings which is all -8 so hopefully it will flow enough!
#462
Posted 02 February 2014 - 09:38 PM
If they use 90 degree fittings on the cooler I may take you up on that!
They do indeed. I think the left hand hose as you look from the front is quite short, might not be long enough for where you have the cooler. I'll measure the lengths tomorrow.
#463
Posted 04 February 2014 - 08:39 PM
Next comes the oil feed for the turbo and adapter for a pressure sensor, then move onto the radiator and boost hoses
Ben
#464
Posted 06 February 2014 - 06:14 AM
#465
Posted 06 February 2014 - 12:19 PM
