Frumpy Gets Some Love
#271
Posted 02 April 2012 - 05:58 PM
#272
Posted 02 April 2012 - 06:01 PM
hopefully not long now until its on wheels (which i still need to get split)
#273
Posted 03 April 2012 - 07:15 PM
ive got my rosejoints through to start making my brace bars once the subframes in and i have some tube.
the clever among you may have noticed that i have two R/H thread rose joints and two L/H thread rose joints. this is to allow me to adjust them slightly to get the right tension i want.
ive also fitted with some missalignment spacers so that i can put a bend in the tube to allow for a standard radiator.
Ben
Edited by benjy_18, 03 April 2012 - 07:16 PM.
#274
Posted 03 April 2012 - 07:18 PM
What are you tensioning, doing etc??
Graham
#275
Posted 03 April 2012 - 07:28 PM
this photo shows how mine will be (azzgranty's idea)
http://www.flickr.co.../in/photostream
having the rosejoints just looks betterand means i can have the tubes offset at an angle to the bulkhead and be removable.
ther adjustment will mainly be to overcome my bad measuring skills but it means that i can put somefore into the bars when they are fitted. similiar to how modern cars strut braces really. it will just be a more efficient way than the usually box section braces bars
#276
Posted 03 April 2012 - 07:33 PM
#277
Posted 03 April 2012 - 07:45 PM
Ben
#278
Posted 03 April 2012 - 09:26 PM
#279
Posted 03 April 2012 - 09:39 PM
Ben
#280
Posted 03 April 2012 - 10:40 PM
#281
Posted 04 April 2012 - 05:55 PM
im still waiting on my CDS for the rear subframe so im going to get the radius arms and rear brakes sorted this weekend and fitted onto the section i have now, then i can sort the rear subframe out and hopefulyl be rolling in a few weeks.
Ben
#282
Posted 08 April 2012 - 03:13 PM
went off to wheels day on friday and turned out to be a great day! some amazing cars over there to take insiration from.
swapped the M10 hex heads for some M10 cap head bolts for the brace bars just for looks
been cleaning all the rear brake components today so i can rebuild them tomorrow and fit them to an old set of radius arms for a test fit
quick photo of my favourite car from wheels day
fully spaceframed ford anglia with cosworth engine!
Ben
#283
Posted 09 April 2012 - 07:31 PM
i did manage to get my rear brakes all built up apart from the hubs which ill be putting new bearings into.
all i can say is that BL should have used bolt in wheel cylinders! those clips are a right pain!!!
Ben
#284
Posted 10 April 2012 - 04:16 AM
#285
Posted 10 April 2012 - 08:00 PM
got one radius arm built up today, its not the final arm ill be using as im going for a refurbed set with the knuckle pot machined off and also may be going for a set of alloy hubs.
ill get the other side built up tomorrow then hopefully build up the rear subframe for mocking up the tubular sections this weekend
Ben
