Frumpy Gets Some Love
#166
Posted 21 September 2011 - 05:49 PM
the door just doesnt sit right AT ALL, but i know thats mostly to do with me cutting the bottom corner out. it can be fixed but its going to take a long time. i have to fix the bottom of the door frame first anyway as thats rusted through. it seams to have been fixed with sealent! i just wish i had a garage to work in so i can be out there for more than 3-4 hours at a time
#167
Posted 10 October 2011 - 06:33 PM
ive been working more on the passenger door step repair which if half done now so i will finish that off tomorrow, once the passenger side is done i can start on the drivers side. im going to be replacing the whole heelboard and remaking my boot floor as im not happy with it.
#168
Posted 11 October 2011 - 05:45 PM
also put the front end on to see how badly it fitted and i wasnt surprised at all! its aweful, so its going to be made into something else and ill buy heritage panels to makemy flip front from.
here are some photos
#169
Posted 11 October 2011 - 06:37 PM
Hugh
#170
Posted 11 October 2011 - 07:58 PM
#171
Posted 12 October 2011 - 09:15 AM
the front subframe is built without the hubs and the rear subframe i have to heavily modify for coilovers anyway.
i start an apprenticeship with hyundai on monday so money should be coming in for much needed parts (Y)
#172
Posted 12 October 2011 - 09:55 AM
#173
Posted 12 October 2011 - 10:22 AM
the money is AWEFUL to say the least but its the only way into the industry at the minute. luckily i dont have a girl to spend the money of so frumpy will be getting most if not all of it
#174
Posted 13 October 2011 - 03:57 PM
managed to finish the N/S door step today and it looks great
now to do the opposite side and sill. once this is done i just have to finish a few bits on the floor and i will hopefulyl be able to get the interior painted and finished.
then the dreaded full heelboard but ive decided to redo my boot floor at the same time as this because im not really happy with how its come out
#175
Posted 13 October 2011 - 09:10 PM
What are you planning for the boot floor? Same again but neater or something different.
#176
Posted 14 October 2011 - 05:51 PM
plans for the boot are pretty similiar really, ive decide to use coilovers on the rear (will upgrade front eventually) which means i can cut even more of my subframe up but i want to keep the subframe rubebr mounted so ill be making a tubular section for it so i can make some rear mounts. this means that i no longer need to ugly recesses in the boot floor so im going to make it perfectly flat but with a recess for the tank (almost like your pro-motive build you have down there) so i can turret the arches at the same time and i might even lock the roll cage into the turrets
#177
Posted 16 October 2011 - 06:15 PM
here are some photos of the progress on thr steering collumn bracket,
ive also remade the brackets for my seats although i didnt take any photos of these
comments welcome
Ben
#178
Posted 16 October 2011 - 06:33 PM
Top work, it's starting to get there!
#179
Posted 16 October 2011 - 06:37 PM
obviously theres ideas i have (rwd) that just arent going to happen anytime soon so im doign as much as i can within reason.
thankyou for the comments though, really helps to keep motivation up
#180
Posted 18 October 2011 - 06:49 PM
both mounts are now in place so once i get my UJ's i will fabricate the rest of the column and get it centred on the rack
