Mini Scura Minus
377 replies to this topic
#256 Manneke
Manneke
  • 46 posts
Posted 31 May 2012 - 06:09 AM
Impressive build thread you have here... enjoy to follow it and learn quite a lot by reading it! keep up the updates ;-)
#257 blue blood
blue blood
  • 806 posts
Posted 31 May 2012 - 06:59 AM
Minus are still going then?
Does he know the website is gone?
Nice update blue those hinges look good. Could you not space them out a little?
Yeah they are still going and the guy does know his website is down. He is quite a hard guy to contact but I got there in the end .
As for the hinges I have made a couple of templates to see how much I would have to cut out of the side for them to flip up and its about 1cm deep and 6cm long. I think if I used spacers it would look right as they would be floating too far out into the engine bay (wouldn't be as stable and could interfere with something else in the bay).
Thanks Manneke glad you like the thread.
Regards Blue
#258 blue blood
blue blood
  • 806 posts
Posted 04 June 2012 - 08:13 PM
So a big morale boost on the project today as I officially have it as a rolling shell since the first time I have owned the shell :) and damn the brake disks look huge in the wheels :blink:
These are only temporary penny washers so I can see the suspension is alright with the engine in.
On all rubbers:
Well thats all today guys. It was a pain in the ass to get this far on the front as I had to cut bolts down for the flanges, take the subframe out a few times to get the correct sides on the lower arms, split all the suspension parts apart to mark measure and drill holes, then drill out the brackets holes larger for metric sizes, then assemble everything basically everything was long winded :( but got there in the end :ph34r:
Regards Blue
#259 Tupers
Tupers
  • 4,176 posts
Posted 05 June 2012 - 01:50 PM
Love the giant brakes, you need to find a air field once it's done and find out the 0-60-0 time.
#260 blue blood
blue blood
  • 806 posts
Posted 05 June 2012 - 03:19 PM
I would love to do that especially after putting it through an SVA, then once the MPI unit has exploded use a 2.0L 8 v vauxhall unit like I have planned :ph34r:
Regards Blue
#261 thelegg
thelegg
  • 612 posts
Posted 06 June 2012 - 09:16 AM
bolt some wings on lol as its gonna fly :L looking great so far though
#262 blue blood
blue blood
  • 806 posts
Posted 06 June 2012 - 03:25 PM
Thanks every one for the comments a small update as I got a few moments in the garage I have drilled the stainless suspension spreader plates:
I'm not a massive fan of garish chrome everywhere but do like some polished stainless parts :)
Regards Blue
#263 jonny f
jonny f
  • 1,493 posts
  • Local Club: Boxhill Mini Club
Posted 06 June 2012 - 09:05 PM
Great updates blue! Awesome to see you have it rolling.
Your suspension looks to be in roughly the same place as mine. The brackets look a little lower, i think i may have to change mine and drop them down a bit as my car sits rather low with no engine in it.
Some very shiney bits in the bay, was confusing my eyes somewhat.
#264 blue blood
blue blood
  • 806 posts
Posted 06 June 2012 - 10:15 PM
Yeah as regards to the suspension they are adjustable and I can raise it or lower it for the position I want but I have to actually cut some of the wing out to allow for the 13x7's to turn properly (its common practise so i'm not to worried)
Yeah with the amount of polished stainless it is like a house of mirrors under my bonnet!!
Ha
Thanks for the comment Jonny
Regards Blue
#265 blue blood
blue blood
  • 806 posts
Posted 08 June 2012 - 08:41 PM
Right got a few parts done recently. I did wire brush and paint in hammerite my backplates a while ago but if you have read my thread you will know I bought a pack of some paint like hammerite/por15 on steroids!!! So I had my backplates shot blasted and painted them. I gave them 2 coats of the base coat formula and one of the black over coat. They look really good and I am very impressed with the outcome:
Then I painted the two alternator brackets I had fabricated:
I then purchased some quick release poly engine mounts as it is easier to get my engine in and out as I mostly work on my own:
Not much but thats all for now folks.
Regards Blue
#266 blue blood
blue blood
  • 806 posts
Posted 09 June 2012 - 11:58 AM
:ph34r:
Edited by blue blood, 11 June 2012 - 10:53 AM.
#267 jonny f
jonny f
  • 1,493 posts
Posted 11 June 2012 - 10:10 AM
Nice work blue,
I've heard a few mixed reviews about those engine mount's. Tempted to get some for mine.
#268 blue blood
blue blood
  • 806 posts
Posted 11 June 2012 - 10:54 AM
Going to give them a whirl today so 'ill report back later this evening about them. I've got a few odds and ends I want to sort out today.
Regards Blue
#269 jonny f
jonny f
  • 1,493 posts
Posted 11 June 2012 - 03:09 PM
Im sanding, as usual!
#270 blue blood
blue blood
  • 806 posts
Posted 11 June 2012 - 07:07 PM
Well got bugger all done today which was a bit disappointing when I spent 5 hours in the garage! I went to put the new engine mounts on but realised the existing bolts weren't long enough and I didn't have any spare bolts!!!
So i decided to make a start on my boot lid set-up. I got as far as cutting the 3mm aluminium angle into the rough shape I needed and drilled holes in it for lightening and better bonding with the boot lid. It doesn't look like much but these are all I have to show for toady:
I will put a curve in them and fibreglass them to the boot lid. It should add more rigidity to the single skin lid and make for a good mounting point as there will be a larger anchorage surface.
Thats all for today.
Regards Blue
