Mini Scura Minus
377 replies to this topic
#211 blue blood
blue blood
  • 806 posts
Posted 24 February 2012 - 09:01 PM
Well time for a few more updates as i've had a bit more time to work on it recently.
I started by trial fitting my tie bars, lower arms, upper arms and hub assembly to check on clearance and fitment. I had a guy from the 16v forum make some lower arm pin spacers up from some spare titanium I had as my lower arms use rose joints:
and fitted
The hub assembly fitted:
I then cut the rear arches back and found that I don't have to tub them as the rear arms would contact the boot floor before the 13inch wheels would come in contact with the arch as shown in the picture:
with the space above I have this much space between the arm and body work(a lot less)
Unfortunately on the one side I did sand back a bit too much so I filled the holes with fibrefiller but will fibreglass over it for strength:
I also started to cut out sections at the top of suspension turrets for more coil-over clearance.
Also made up some card templates and covered them in cling film and masked them in place to fibreglass over:
Got going on my rocker cover again. I started by nitromorseing off the paint:
Then wire wheeled it to remove the rust on the inside and outside:
Then Krusted the outside:
I also added a few more holes to the rear spreader plate to keep the plate in place:
Aslo made up the roll-cages new plates for the front four feet in 3mm mild steel:
And finally the obligatory dust drawing on the screen of some evil eyes :ph34r:
Regards to all Blue
#212 blue blood
blue blood
  • 806 posts
Posted 28 February 2012 - 08:03 PM
Back on it the last few days but not much done due to lack of funds and my daily driver needing fixing for an MOT re-take. Since last time I have been able to fit the offside radius arm:
again I had to drill a hole to allow my allen key to reach the bolt to tighten.
I did start doing some fibreglassing on the rear suspension turrets but I only had a bit of resin so it is still to be continued. What I have planned is build up the recess' first like in the pictures then put fibreglass strips across the whole turret to strengthen.
Finally I gave my rocker cover a lick of zinc primer, it will eventually be satin black.
Thats all for now folks.
Regards Blue
#213 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 28 February 2012 - 08:20 PM
Nice work blue! Where do you get your fibreglass from?
#214 blue blood
blue blood
  • 806 posts
Posted 28 February 2012 - 10:16 PM
so far i've been using halfords finest but I will be getting it from this website from now on :) http://www.fiberglas...resin_kits.html
Prices seem really good for what you get in comparison to others on the net or in the shops.
Regards Blue
#215 blue blood
blue blood
  • 806 posts
Posted 01 March 2012 - 10:01 PM
Well for its debut I bring you my bonnet badge design:
I have already had them made a while ago didn't really want anyone stealing the design but I thought if someone really want the design they could get it once my car is finished :)
Regards Blue
#216 jonny f
jonny f
  • 1,485 posts
Posted 01 March 2012 - 10:09 PM
I like it!
Like the wings with a little more detail than normal.
#217 blue blood
blue blood
  • 806 posts
Posted 01 March 2012 - 10:18 PM
I like it!
Yeah more detail and sharper than the normal wings but with more character than the bini badge design :P hahaha
Regards Blue
#218 blue blood
blue blood
  • 806 posts
Posted 05 March 2012 - 04:23 PM
Tiny bit of an update. Managed to get two coats of normal primer on over the zinc primer today. I think I will put two more coats on then start with the satin black. I'm quite happy with it to be honest. I used a bit of filler on the top and across the welded over oil neck and it has all turned out pretty smooth:
Also got my rear quarter windows from plastics for performance all E marked up for the SVA man. Patterns For them were ones I made and they fit like a glove :ph34r:
Thats all for now.
Regards Blue
#219 blue blood
blue blood
  • 806 posts
Posted 07 March 2012 - 07:36 PM
Gave the rocker the last few coats of its colour today and I think its turned out pretty good :
I think it would be nice to maybe have something on the replaced oil cap space like a vinyl but not sure what of. Come to think of it i'm not sure if a vinyl sticker will be able to take the heat ?
Regards Blue
#220 blue blood
blue blood
  • 806 posts
Posted 09 March 2012 - 06:45 PM
Right I got some work done to the shell today. I managed to fill in and strengthen the rear turrets ready to test fit all the rear suspension and wheel setup. It doesn't look like much, but it did take me the whole day to do properly. I bought this kit off ebay : http://www.ebay.co.u...97#ht_872wt_956
I have to say it is a lot easier and gives a more professional finish/look/strength than the 'Davids' crap that you get from halfords. The pack has really sent me a long way and I have loads left over. I wish I would have bought this stuff when I first started my project (it would have saved me a bob or two).
Anyway here is the work I got done with the kit:
Filling in the holes with layers cut to size-
I started the one side with the halfords kit but today layered it up a bit more with the new kit:
Then strengthening/reinforcing all the top of the turrets-
Then I stuck my freshly painted rocker cover on the engine with its cap on to see what it looks like:
Which is dusty! but still looks good :)
Thats all for toady.
Regards Blue
#221 jonny f
jonny f
  • 1,485 posts
Posted 15 March 2012 - 11:13 AM
Looks great blue.
I have mine on four wheels now ;)
#222 blue blood
blue blood
  • 806 posts
Posted 15 March 2012 - 07:10 PM
Cheers Jonny as you see i've been doing a few different things but i've been at work and will be all week and weekend some not much progress i'm afraid. I hope to have mine on all fours soonish :)
Regards Blue
#223 Manneke
Manneke
  • 46 posts
Posted 17 March 2012 - 08:40 PM
a very impressive project, good luck with the rest!
#224 blue blood
blue blood
  • 806 posts
Posted 17 March 2012 - 09:11 PM
Cheers mate I hope to crack on with it after this weekend (helping my mothers business as she's a florist)
Regards blue
#225 blue blood
blue blood
  • 806 posts
Posted 21 March 2012 - 08:33 PM
So finally got some time to work on my car today. I managed to drill the final spreader plates for the rear beam. Do the final fibreglassing in the rear wheel arches and get the arms/suspension on:
Then I got moving on the roll cage I have had the feet tacked in place but on three of them i'm going to grind the tacks off and file them down to fit to the spreader plates a bit better ready for fully welding:
Regards Blue
