The original and perfectly satisfactory earth was indeed from one of the "wok" bolts to the inner wing, but later it got moved to the top steady, which is actually not very satisfactory. It is a good idea, with no downside, to add one to the inner wing. You could also go from one of the diff casing studs to the toeboard, on one of the subframe mount bolts.
Remember that if the earth is not good enough, the heavy starter current has several alternative paths available to it. One, well-known, fries the choke and/or accelerator cables, but the other one, which does expensive and initially unseen damage, is through the diff, pot joints, driveshafts, hub bearings, top balljoints, top arm bearings, subframe, and on rubber mounted subframe cars, the main brake pipe. And yes it does go that way, we had someone here a while back who was finding that the brake pipe was getting so hot that the fluid was boiling. Rolling element bearings are damaged by fairly small amounts of current, so bad earths are very likely associated with short-lived diff, hub and top arm bearings, the hub bearings being the most vulnerable as the diff also has plain bushes and the top arm current may pass through the thrust washers..
Edited by tiger99, 17 October 2013 - 11:06 AM.
