Engine Identification
5 replies to this topic
#1 Carlos W
Carlos W
  • 10,114 posts
Posted 04 December 2010 - 04:26 PM
Hi,
I'm tring to get the spec and approximae age of a spare engine I have
The engine number is 99H-137-H38***
I'm sure it's a very early 998cc but wondered if anyone could tell me any more!
I'm going to sell this as it's surplus to requirements and I wanted to describe it as well as possible!
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 December 2010 - 08:51 PM
Somewhere between 1970 and '74, A series, unless it's an earlier 998 cooper
Check the head casting number, look for 295, and then look for a piston with a crown, rather than a dish or flat.
If no 295 and crowned pistons then it's just an ordinary 998 of the above period.
#3 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 04 December 2010 - 08:56 PM
According to my old BMC parts book (AKD 5103 issue 4)
99H is a 998 transverse (obviously)
137 engine had a 40C Dynamo and a standard ratio remote-control gearbox
H***** is high compression.
Edited by surfblue63, 04 December 2010 - 09:00 PM.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 05 December 2010 - 10:49 AM
Thanks guys, I'll go down to the garage in a bit and check the head casting, never noticed the numbers before though!
Any idea where the numbers would be?
#5 tommy13
tommy13
  • 878 posts
Posted 05 December 2010 - 12:07 PM
The numbers are cast into the top of the cylinder head between the tow centre rocker support mounting faces.
Can be seen on this one on Ebay
http://cgi.ebay.co.u...=item4cf399e0af
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 05 December 2010 - 12:31 PM
That'll be why I've never seen it, I'll go and pop the rocket cover off!
