1980
I purchased a second hand disc setup from a forum member. He said everything was good to bolt straight on to convert my drums to discs.
So far I have discovered and rectified the following...
The ball bearing 'knuckle' on the discs driveshafts are bigger than the drum counterpart - swapped over
Discs and pads were shot (would have replaced anyway) - replaced
Rubber brake hoses replaced with braided ones.
Having fitted the setup for the third time...grrr...I noticed that there was movement when i pushed the top and bottom of the wheels (car was on stands) I assumed it was worn wheel bearings so ordered a set for each side.
Just spent 4 hours in -3 degrees (wish I had a garage) pulling the front hubs off, removing old bearings (didnt seem too bad) and fitting new ones, well packed with grease etc.
Fitted OS first, torqued hub nut and all semed fine, did the NS, finished everyhtnig up, tested and there is still movement! Went back to check OS and there seems to be slight movement there too...my fingers and toes were hurting by this stage
Any suggestions?
Outer CV need replacing maybe? Although during assesmbly everthing seemed to fit well.
Any advice would be greatly appreciated.
Thank you in advance.
matt
Edited by charm_muppet, 03 December 2010 - 05:50 PM.
