Windscreen Washers Blocked/frozen
11 replies to this topic
#1 paulfoel
paulfoel
  • 205 posts
Posted 02 December 2010 - 04:02 PM
Model:
Cooper (Jap)
Year:
1987
Dont know if they're frozen or just blocked.
Tried unblocking nozzles no joy. I see fill bottle is in boot. anyone know where the water line runs so I can try and see if its frozen
#2 Chris_R
Chris_R
  • 399 posts
Posted 02 December 2010 - 04:06 PM
This time of year it's highly highly likely to be frozen unless you're running almost neat screenwash fluid in it!!!
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 December 2010 - 04:28 PM
Drive the car for 10mins, engine heat will defrost it.
#4 shellspeed
shellspeed
  • 233 posts
Posted 02 December 2010 - 04:54 PM
On mine the water tube goes up the rear pillar and along the roof just above the door and then down the side of the windscreen in the pillar.
J
#5 paulfoel
paulfoel
  • 205 posts
Posted 03 December 2010 - 11:56 AM
How does engine heat defrost it if the water line is running from the back of the car?
#6 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 03 December 2010 - 12:41 PM
It doesn't, I guess he didn't read the "Jap" part...
When they freeze up there isn't much you can do (unless you really want to get to the pipes in the roof lining), but mine usually only freeze close to the nosel end, they do block up well from time to time so try unblocking first.
#7 chrisholland1983
chrisholland1983
  • 1,359 posts
Posted 03 December 2010 - 12:51 PM
mines not "jap" and its in the boot
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 03 December 2010 - 01:10 PM
Engine hot, things in engine bay get hot, defrosting happens.
#9 Cooperman
  • 23,276 posts
Posted 03 December 2010 - 01:26 PM
Put a fan heater underneath the car for an hour of so whilst running the engine to get the inside of the car warm. You might also need to warm the inside of the boot too. That should melt the ice. Then add 50% windscreen solvent and pump a load through until it's got the solvent all through the system.
#10 paulfoel
paulfoel
  • 205 posts
Posted 03 December 2010 - 01:50 PM
Hmmm. Thought it was just jap ones had it in the boot.
I'm guessing the jap models have got them in the boot due to lack of space in the engine bay (filled up with AC unit)?
#11 paulfoel
paulfoel
  • 205 posts
Posted 03 December 2010 - 01:53 PM
I think the problem stems from the fact that the bottle was never refilled with proper screenwash - just water :thumbsup:(
#12 bobs
bobs
  • 512 posts
Posted 03 December 2010 - 02:06 PM
That's what I assumed, I know 1992> have them in the boot also...
