Machining Cost
17 replies to this topic
#16 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 26 November 2010 - 04:15 PM
£160 is about what might be expected if you supplied the guides as free-issue. The 4 off seats can't cost much really.
Were you doing your own valve lapping-in?
Yes guna do my lapping myself, also done the porting myself aswell, once reasembled I can measure the cc and see what needs skimming to get the CR Im after, also guna get crank and fly balanced
#17 Cooperman
  • 23,278 posts
Posted 26 November 2010 - 04:31 PM
Some will disagree, but balancing is not really needed unless you want to regularly use over around 6000 rpm. Done properly it is not cheap and some so-called balancers don't do a very accurate job. Just lighten the flywheel a bit to improve acceleration and use a cam hat has max power at around 5700 rpm and it'll run very well.
What CR are you going to set it to?
#18 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 26 November 2010 - 05:00 PM
not really sure what CR Im after really, Ive got an ultralight fly and ultralight backplate to go onto my build already :blink:
going for a 276 kent
may skip the balancing then as I have never even taken my girly over 5000 revs, will save me £75
