Wide Outer Sills
24 replies to this topic
#1 danny164
danny164
  • 28 posts
Posted 25 November 2010 - 10:49 PM
need new outer sills and wondering what the point of wide outer sills... how are they different to standard? any help would be appreciated thanks
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 25 November 2010 - 10:52 PM
They are normally used to cover up rust damge etc, normally known as oversills. Generally hated by all mini owners. Buy the proper sized ones then you know nothing is being hidden.
#3 mike.
mike.
  • 6,176 posts
Posted 26 November 2010 - 12:55 PM
As above, they're often fitted over the rusty original sills and generally when fitted, means that the old sill and inner sill are underneath them rotting away.
Although they can be fitted properly by removing the original sill and fitting the wider over sill in its place. My car had an oversill fitted on the drivers side, and when it was took off there was no original sill underneath and the inner sill and floor was in good nick.
I don't think oversills are too bad when done properly as long as the metal underneath them is in good condition and then once fitted they can be pumped full of waxoyl or old engine oil to protect them. Although it does mean that the sill box section is effectively sealed off and should any condensation form, it has no way of draining or venting out.
Edited by mike., 26 November 2010 - 12:57 PM.
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 November 2010 - 01:45 PM
in a word do the job properly and no
dave
#5 danny164
danny164
  • 28 posts
Posted 26 November 2010 - 05:01 PM
ordered the standard sills.... not messing around hiding rust its my little project and i think it need doing right only be a bigger problem for me in the future if i take the short cut thanks for the help :blink:
Dan
#6 miniman24
miniman24
  • 1,696 posts
Posted 26 November 2010 - 06:38 PM
Not much help now, as youve already ordered, but i went half and half - 4 1/2 inch sills, purely because they were so much cheaper than standard size ones :-
#7 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 27 November 2010 - 06:17 PM
how fewer plug welds holding that sill on? and could properly do with a few in the floor to the sill to give the car more strength
dave
#8 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 November 2010 - 06:23 PM
That could fail the mot, spot welds should as per the manufacturer or at least a minimum of 1" apart.
#9 Tupers
Tupers
  • 4,142 posts
Posted 27 November 2010 - 06:48 PM
It's worth stating that wide sill and cover or over sill are two different things although in some cases they might be used for the same purposes of covering rusted o.g. sills. A wide sill is obviously deeper but still has open vents for ventilation where as a cover sill has sealed vents not allowing any airflow through the sill.
I used wide sills on my Estate as I think the extra width looks a bit nicer to be honest and are fitted in the same way as a genuine sill would be.
#10 R1mini
R1mini
  • 1,387 posts
Posted 27 November 2010 - 06:55 PM
Wide sills can be useful, years ago they were used as a cheap and easy way of scraping through an MOT one more time. I wouldn't entertain spending £500 per side on a heap with a limited life. Anything decent then it wants to be done properly
David
#11 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 27 November 2010 - 07:07 PM
David
A man after my own heart!
Oversills have saved more minis that anything else.
When I get a rusty sack of crap in and end up peeling off 3/4/5 oversills I know that that car has had stay of execution for 5-8 years.
Minis weren't always a cherished classic, they were cheap a-b transport. Having the work done properly would have exceeded the value of the car and hence it would have been scrapped and lost.
I still get asked to fit oversills, I still fit oversills!!
To remove oversills and replace with proper ones is £300 per side min, most owners can't afford a bill like that. Chucking a pair of oversills on is about £175 fot the pair.
Yes they aren't the best idea but they do prolong the life of your car. They aren't as bad as the cover panels availible for the inner sill though.
#12 IainR
IainR
  • 251 posts
Posted 06 December 2010 - 12:59 PM
Not much help now, as youve already ordered, but i went half and half - 4 1/2 inch sills, purely because they were so much cheaper than standard size ones :)
Tell me you didn't work under the car supported by that pile of wood??!!
Edit: I've noticed that "wood" looks like offcuts of kitchen worktop!!!!
Edited by IainR, 06 December 2010 - 01:00 PM.
#13 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 06 December 2010 - 01:18 PM
Oversills were used to repair mini's that had already had a set of replacement sills or two. The rust would attack the floor where it was welded on , hence the need for a wider sill.
Mini's were repaired in the past and not restored.
If you chop the old sill off and fit an oversill and you car does not become another unfinished project then go for it. Drill somes holes in it and Waxoil it inside.
Edited by mk3 Cooper S, 06 December 2010 - 01:21 PM.
#14 miniman24
miniman24
  • 1,696 posts
Posted 06 December 2010 - 07:45 PM
Not much help now, as youve already ordered, but i went half and half - 4 1/2 inch sills, purely because they were so much cheaper than standard size ones ;)
Well, not under it, more to the side of it... the axle stands were under the jeep, and i wanted to get started! And yes, i have heard this before :(
Yeah, my dads a builder/carpenter, so we get free offcuts for the fire, or for emergancy axlestands!
Edited by miniman24, 06 December 2010 - 07:46 PM.
#15 Deepender90
Deepender90
    Starting My Mini Up
  • 3 posts
Posted 06 December 2010 - 08:29 PM
I've told him before. If i did that at work my boss would have my nuts off.
