![Posted Image](http://i884.photobucket.com/albums/ac45/woodsy483/mpinumberedhose.jpg)
![Posted Image](http://i884.photobucket.com/albums/ac45/woodsy483/mpienginebay.jpg)
I dont want people saying why change from the standard as I've alreadsy spent the cash on parts inc expansion tank, fan etc
Any help appreciated
1.
2.
3.
4.
5.
6.
7.
8.
Posted 24 November 2010 - 01:10 PM
Posted 24 November 2010 - 01:16 PM
Have you tried fitting the front rad in? I think it will be very tight with the distrtibutor. Don't make the mistake of squeezing in the rad, then finding out you cannot remove the HT leads / cap to change the rotor arm...1.Thermostat sandwich plate
2. Through bulkhead - heater?
3.Expansion tank
4. Water pump
5.Through bulkhead - heater?
6. Radiator
7. Radiator
8. Thermostat housing
Edited by L400RAS, 24 November 2010 - 01:18 PM.
Posted 24 November 2010 - 01:23 PM
3.Expansion tank
4. Water pump
6. Radiator
7. Radiator
(cough - stick with the side rad... (sorry))
Posted 24 November 2010 - 01:27 PM
Ok, but the same applies to your alternator. The MPi had a one-off alternator, hung from lugs on the cylinder head. Have you got enough space with the traditional alternator?Thanks, I'm going megajolt so dizzy wont be a problem
Edited by L400RAS, 24 November 2010 - 01:27 PM.
Posted 24 November 2010 - 01:33 PM
Posted 24 November 2010 - 03:36 PM
Posted 24 November 2010 - 04:22 PM
If you use a tensioner pulley you can swing the alternator up out of the way...... you would need some bracketry to do this but it does work
Posted 24 November 2010 - 04:36 PM
Posted 24 November 2010 - 05:22 PM
Are you getting the Viper hoses, as thats an expensive bit of pipe to start cutting into
£170
Try on flea bay, they sell pipes to fit mpi (not one piece molded) from china n the like
Posted 24 November 2010 - 05:38 PM
Posted 24 November 2010 - 05:44 PM
Posted 24 November 2010 - 05:50 PM
Posted 24 November 2010 - 06:45 PM
Have you done this yourself?
If so can you tell me did you just use a cam belt tensioner pulley and how did you mount the bracket? Any pics, a picture paints a thousand words an all
