Electrical Schematics
9 replies to this topic
#1 frog998
frog998
  • 595 posts
Posted 23 November 2010 - 01:57 PM
Anyone got any electrical schematic drawings for a 1990 998?
Got no power to the rear fog light so need to trace where the wire comes from, hopefully its just from the fog light switch and direct to the light if so then i can just run another wire to make it work.
#2 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 23 November 2010 - 02:14 PM
Buy a Haynes manual, they're very useful for things like this.
#3 frog998
frog998
  • 595 posts
Posted 23 November 2010 - 02:24 PM
If a had a haynes i wouldn't of asked but as i dont then.........
#4 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 23 November 2010 - 02:33 PM
It should be just a single wire from the switch to the fog lamp it is blue with yellow tracer. The lamp may also a black wire for earth or it may just pickup the earth through the fixings. Have you checked the bulb? I'd get a haynes manual too
#5 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 23 November 2010 - 04:37 PM
Could be the switch itself. Mine gave up on me last week again. Ive already repaired it once. As said though its blue with yellow tracer. Runs straight from the switch to the lamp.
#6 bobs
bobs
  • 512 posts
Posted 23 November 2010 - 05:16 PM
Cheaper than a multimeter........
#7 pikey7
pikey7
  • 3,824 posts
Posted 23 November 2010 - 05:44 PM
I didnt think it was possible to own a mini for more than 3 days hours and not need a haynes manual?
#8 morley
morley
  • 903 posts
Posted 23 November 2010 - 06:08 PM
http://www.b0lus.com.....am (1970).jpg
and key:
http://www.b0lus.com.....1970) key.gif
NOT mine may i add >_<
#9 frog998
frog998
  • 595 posts
Posted 23 November 2010 - 08:03 PM
I used to have a Haynes and since i've moved house i cant find it.
I already have a couple of multimeters just wanted to double check it was a wire direct from the switch as i have voltage at the switch when the switch is off but lose the voltage as soon as its switched so i think i either have a broken wire or a corroded terminal somewhere. So now i know its 1 wire i'll run a proving wire and if this is ok then i'll fit it correctly.
#10 frog998
frog998
  • 595 posts
Posted 24 November 2010 - 12:24 PM
Oh well had a play and it looks like the fog lamp itself is cream crackered, wheres best place to get 1 from?
