7 Port Head - Engine Spec?
Posted 19 November 2010 - 10:38 AM
I am looking at the SC kit, its basically bolt on, but i wonder what the spec of the block should be for best results?
Craig
Posted 19 November 2010 - 01:19 PM
http://www.med-engin...mp;vlang_id=562
276 cam perhaps for something thats entirely tractable, but with a cross flow head you could probably get away with a 296 and it be easier to drive then a 276 in a 5 port.Â
decent 1.5:1 ratio roller rockers
omega or powermax cast pistons unless its a race engine.Â
the rest being mostly decent quality standard components ect....
A decent rebuilt box with a cross pin diff on helical drops should suffice for the gearbox.
I wouldn't say its just a bolt on job! You will have to adapt the car a little bit to run the injection.
Edited by Sam Walters, 19 November 2010 - 01:20 PM.
Posted 19 November 2010 - 02:47 PM
JK
Posted 19 November 2010 - 03:03 PM
I had originally thought about a project mini with some sort of conversion perhaps pro-motive, but the Swedish fun killers have killed that idea as the Bhp to weight ratio is too high!
So have been looking at the 7 port head for my current mini!
Its an 96 SPi; is there any reason why this block cant be used?
I do wonder about the emissions levels of a 7port head though as its very strict here, especially given the car is a 1996. Any comments of that?
I guess it would be possible to run different ecu maps to over come this?
The 7 port is sounding perfect. I mostly use the car in the city, with a 15 km trip to work a couple of times a week, so its low down power and torque i am after!
@john I will look out for the magazine since youve mentioned it - although its a pain the #¤& getting it, involves a train trip to Denmark!
Oh and Johnk whos "we"?
Posted 19 November 2010 - 04:50 PM
John is SC's engine Guru.
just for the record hot cams are more important on other 7 ports due to their larger ports, but that beside the point, the SC one is the one to go for.
Posted 19 November 2010 - 05:01 PM
Posted 19 November 2010 - 05:57 PM
Posted 20 November 2010 - 08:08 PM
How would the smaller valves compare with a 5 port 36/31 or 37/31?
Do you know if you can fit twin 40s with this head under a std round nose bonnet and use filters?
Posted 20 November 2010 - 08:16 PM
Posted 21 November 2010 - 10:14 AM
Just looking at the HRE, SC and MED heads and I notice the HRE version is running much smaller valves (33.5/29.5) compared with the others (36/31 & 37\30 respectively). Do you think you would notice much difference?
The thing with a 7 Port head is that bigger is not always better in respect to the valve size. The 7 Port head already flow's a lot better than you would get from a 5 port so having such large valves fitted is not always the right route to take, infact it could even make you loose some bottom end power.
A friend of mine running a 7port with 37/31's with a similar spec 1380 as myself only managed 1 lbs ft more than myself on the rollers over a 35/31 5 Port head, albeit it made 23bhp more than my setup though.
I seem to recall you can't fit the 40's under the bonnet with the above head's mentioned although I'm not fully sure but I imagine someone will be along who does know soon.
Posted 21 November 2010 - 10:23 AM
What is the car like; lots of low down power /torque?
Posted 21 November 2010 - 10:42 AM
Southy - What made you go down the 7 port route instead of something else!
I haven't myself, I'm still running a 5 port head though would like to add a 7 port head on it at some stage, if I decide to keep the Mini. My friend is running the 7 port and it is really nice to drive and pull's fairly well from the bottom end, but I suppose with it being run on injection helps out.
Posted 21 November 2010 - 06:23 PM
if you buy from webcon they come with girls valves and you have to change them to mans valves.
I am in the middle of a 7 port turbo, currently doing the Plenum, 7 ports can still cost alot unless your sticking to carbs or have deep enough pockets to pay others to do it.
Posted 22 November 2010 - 06:50 PM
Also any one who has the head with the new ECU - does the ecu contol the lambda sensor. Im thinking about strict emissions in the swedish mot since teh car is a 1996!
Posted 22 November 2010 - 08:47 PM
The Lambda is not controlled if anything its the other way round, Lambda's send signals to the ecu.
