Loud Screeching/grinding Noise Coming From Front Left Wheel, Cv Joint?
Posted 17 November 2010 - 11:37 PM
My 1989 Austin Thirty Mini has is making a really loud screeching or grinding type noise when driven, coming from the front left wheel. I reckon its the cv joint as the previous owner mentioned it was on the way out when he sold it to me.
It screeches when driven in a straight line, gets louder when turning to the right and sometimes disappears completely when turning to the left. Ive also noticed the left wheel occasionally stops turning with the engine and I get a slight jolt when it re-engages again (big problem!)
Can anyone confirm that it is the cv joint before I start pulling things apart. Also, does anyone know roughly how much it would cost a garage to fix this as I need it doing quickly and probably dont have all the right tools with me at the moment.
Sam
Posted 18 November 2010 - 12:16 AM
Posted 18 November 2010 - 11:18 AM
The car doesn't pull one way does it? Doesn't brake funny? If you put on the brakes, does it still happen? It could be something lightly rubbing the drums/discs.
Grinding sounds like a bearing. Screeching usually means flat surfaces rubbing (like brakes). Unless it's flat surfaces with grit in them :0
Posted 18 November 2010 - 11:23 AM
CV's do very little when doing in a straight line, Could be a wheel bearing, but debris behind the brake shield makes the most noise.
but if the bearing/track in the CV is fractured or broken, then it would quite possably squeel and make horrid noises in a straight line too
More noticably under load, ie when turning
Posted 18 November 2010 - 11:47 AM
Im leaning towards wheel bearing or cv joint, its not a constant "on" grinding noise, sounds like something on one side of the wheel axis is causing it to rub so you get the grinding noise on/off/on/off etc, getting quicker as you travel quicker.
My main though being that the wheel seems to disengage from the engine occasionally (usually on corners) leaving you on 1WD for a moment before it engages again with a tiny jolt. Could a dodgey bearing do this or is my cv joint truely mashed?
Posted 18 November 2010 - 12:15 PM
Posted 18 November 2010 - 01:49 PM
Posted 18 November 2010 - 05:00 PM
Could be the brackets holding the brake shield have broken. My daughter's did this it it sounds like the same. If it is take it off and bin it.
I had the same problem with the brake dust shields (actually have had it on both sides) on my Mini 30. Made horrible sound like the one you describe. Easy enough to fix by welding the bracket back together.
Posted 18 November 2010 - 07:46 PM
brake thingies
One of them was corroded and had buckled a bit and fallen onto the brake disc. The sound lasted about 5 minutes worth of driving to get it back to the house and about 5 seconds of the missus driving to see if she could hear it. At that point, the excess metal was ground off and it stopped making the noise. got the new thingies fitted today.
Posted 20 November 2010 - 01:32 PM
Any tips on fixing this?
Thanks everyone!
Posted 20 November 2010 - 03:21 PM
Taper roller type bearing, make sure you get the centre spacerAny tips on fixing this?
I would use a brass punch though
Consider doing the swivel joints too
Edited by charie t, 20 November 2010 - 03:23 PM.
Posted 20 November 2010 - 03:29 PM
Just saying, when I did my bearings the brake hose was so rusted I couldn't get it off. Ended up waiting ages to get one delivered.
Posted 20 November 2010 - 07:20 PM
Posted 24 November 2010 - 09:08 PM
Next problem is getting the hub off. It seems to be fused to the bearings somewhere. Ive got the outside bearing on fully turning (on the driveshaft) and the inside bearing seems to be free but the hub just wont come off. Any tips?
Its definitely the bearings, I can see them now and theyre all sideways and in bits, fun times.
Any ideas how to get the stuck hub off? Ive emptied most of a can of penetrating oil into it and given it a lot of whacks with a soft hammer. Im thinking tomorrow go get a blowtorch and get some heat to it.
Posted 24 November 2010 - 11:30 PM
