Turbo injection
#61
Posted 16 December 2005 - 10:38 PM
http://www.sdsefi.com/injectors.htm
#62
Posted 16 December 2005 - 10:41 PM
Well thats the thing, the bulk head box is done so thats why the t3 was probably easier now its all done. But with all this talk of the t2 i just woundered if it was much more work? I heard something bout the actuator needs re mounting and the compressor housing needs turning round? Plus the t2-t3 adaptor plate!
If the box is done - you have two choices:
Mount the T2 onto the T3 manifold using an adaptor plate (see link below).
You then have to cut-and shut the elbow to mate with the downpipe, or make a new elbow/downpipe complete. You will have to index the centre core to get it vertically oriented, and then the compressor housing.
Then you need to weld a pipe onto the compressor outlet as this is too close to the manifold for a hose. Then you need to mount the actuator on a bracket you'l fabricate / modify.
Then you need to plumb in the water-cooling (if you wish).
Then you have to fabricate an oil drain
Then you have to get a new oil supply pipe - or just the union if you already have a flexi-hose as the T2 is a different inlet fitting to the T3 (there are two T2 threads aswell!!!)
Link for adaptor plate:
http://www.netsnapsh...=2&ACCOUNT=4541
Link for doing the T2 on Mirage:
http://www.turbomini...p?p=vt&tid=5742
#63
Posted 16 December 2005 - 10:43 PM
Just about... you can run to near 300 on std injectors with some very careful mapping.
But greys are nasty and old tech (like my lovely T3s...)
but you know what they say black is the new grey!
Alex
#64
Posted 16 December 2005 - 10:48 PM
High impedance by chance??? (doubt it!!!!)
I'll upload a picture of the MPi nozzle - it looks a lot different to any i've seen before (or since)...
As i said on 16v mini - these look like real hidden gems in the 'buget' tuning world!!!
#65
Posted 16 December 2005 - 11:01 PM
#66
Posted 16 December 2005 - 11:09 PM
#67
Posted 16 December 2005 - 11:14 PM
#68
Posted 16 December 2005 - 11:24 PM
#69
Posted 17 December 2005 - 05:13 AM
Not got any AR charts, nope...Never having worked with T2's have you got ant AR charts for them ??
Never seen one infact.
#70
Posted 17 December 2005 - 08:41 AM
But then again how many bhps do you want?
lol
Alex
#71
Posted 17 December 2005 - 01:16 PM
Quite alot of work to fit the t2 then. Think i'll raise the cr like i previously said and run a t3. It'll be interesting to see if it does work out reliable, be fun to i suppose! But im gonna keep working on this head to lower the cr that way iv got a fall back plan!
Cheers! :grin:
#72
Posted 17 December 2005 - 01:24 PM
Cheers! :grin:
#73
Posted 17 December 2005 - 06:26 PM
How much earlier do they come on boost when compared against a Metro T3 ?They run out of puff above 170bhp, T2s that is....
lol
Alex
#74
Posted 17 December 2005 - 06:39 PM
Cheers! :grin:
#75
Posted 17 December 2005 - 09:53 PM
