Turbo injection
#46
Posted 16 December 2005 - 09:28 PM
#47
Posted 16 December 2005 - 09:29 PM
Offset bore it out +60(1330)
Offset grind the crank to a longer stroke and use S rods to increase the capicity further hence bring the turbo on quicker.
Lower the C/r as normal.
Use a mild cam maybe even a standard MG one
Don't use an intercooler as Ive heard this increases the lag
Fit a T2 with the mirage manifold.
HIFF 44 Turbo Su
Use a decent dumpvalve or recirculating valve.
Use a 3.6 or 3.44 instead of a 3.1 or 2.9 diff to keep it on boost more of the time (But that all depends on how you drive it)
Just a thought
#48
Posted 16 December 2005 - 09:34 PM
Here is what you need with the injectors...
(see what i mean about the numbers - the MPi ones are actually 480cc/min - not what i said previously!!!
http://www.16vminicl...opic.php?t=4285
Answers the lot!
200/400
=> 92 (M series) MYJ10011
92=>96 (T nasp) MJY10029
92=>96(T Turbo) MJY10023
600
=>AM246796 (T Turbo) MJY10023
BM246797=> (T Turbo wasted spark?) MJY100460
800
91=>AM152056 (T nasp) MJY10011
AM152057=>230966 (T nasp) MJY10029
91=>230966 (T turbo) MJY10023
96(230967)=>(T Turbo + nasp) MJY100460
MJY100460 also fits
MPI Mini
RT420 T nasp
#49
Posted 16 December 2005 - 09:38 PM
So im gonna be lookin at fitting a t2 then? iv got a brand new one off my rs in the garage, where can i get the mirage kit from? plus how much?
So iv established that i should continue opening the chambers on my head to around 8.4:1, use a t2, i/c, what kind of boost? i was thinking no more than 10psi as the box has the standard internals still thinking whether the twin pin diff is worth it.
Cheers! :grin:
#50
Posted 16 December 2005 - 09:39 PM
#51
Posted 16 December 2005 - 09:41 PM
Cheers! :grin:
#52
Posted 16 December 2005 - 09:46 PM
Cheers! :grin:
#53
Posted 16 December 2005 - 09:50 PM
#54
Posted 16 December 2005 - 09:52 PM
The CR thing is an interesting one for sure... I don't reckon you need to go anything like that low for what you're wanting (10psi) why not aim for 9:1 - which'll give a little leeway for if you get a bad tank of fuel...
Headgasket was discussed in a different post a few days ago. go with the reccomendations. A 998 gasket on a 1275? Whoever gave you that advice - be wary of. That is extremely bogus! :sad:
Sprocket - someone claims they're Nippon Denso items. To be honest - I can't confirm this. There is a logo on the injectors, which i'll attempt to picture and upload. Maybe someone will recognise the logo and confirm it!
#55
Posted 16 December 2005 - 09:55 PM
I am sure that everyone "listening" will agree with me on this point, FIT a twin pin diff as a minimum requirementboost? i was thinking no more than 10psi as the box has the standard internals still thinking whether the twin pin diff is worth it.
It will be a lot safer - take my word for it if you have had a single pin fail exciting a hard corner you would fit one as a matter of course.....
This is in part due to the possibility that you will want to "raise" the boost later on.
#56
Posted 16 December 2005 - 10:06 PM
So out comes the engine again! Its been in and out that many times just lately with the change of plans and ideas! So basically iv got to sort my plan and stick to it! im not getting anywhere fast! still need to sell my 2 rs turbos to fund future projects!
So im now lookin out for a mirage kit! what else do i need to do when fitting the t2 on the mirage? I think i just stuck with the t3 for ease, if i remember correctly!
Cheers! :grin:
#57
Posted 16 December 2005 - 10:17 PM
End of the day - a mirage kit - even when used - will be worth at-least half whatever you pay new for it (lifetime warranty) so it's money well spent.
But - you need to follow the advice of everyone before, and fit an uprated diff... So, the engine has to come out... Once the engine's out - how much more effort is a bulkhead box?
ooops, Think i've just confused you again! :grin: :erm: :sad: :grin: :erm: :sad: :grin: :erm: :grin: :erm: :sad: :grin: :erm: :sad:
#58
Posted 16 December 2005 - 10:21 PM
Three letters and then a number up to six places.
Is there no other number, like the bosch items, located on the plug housing. sorry I know if there was then you would have seen it.
They look awfully like Bosch items to me as the Denso ones are totaly different
http://www.globalden...s/injector.html
#59
Posted 16 December 2005 - 10:25 PM
Is there any truth in the usage of the 998 head gasket on the 1275 turbo?
I feel like going to the lock up and cracking on with it now!! Not to sure the neighbours would agree to that tho! :grin:
Cheers! :grin:
#60
Posted 16 December 2005 - 10:33 PM
Here is where the injector discussions took place:
http://www.msefi.com...pic.php?t=11464
You can just make out the logo (two overlapping ovals) on the RH view - just above the D of D3184GB ...
