Going to be taking out the front subframe on my 97 MPI just need to know the correct bolt head size of the tower bolts
Any ideas?
Posted 14 November 2010 - 08:54 PM
Posted 14 November 2010 - 09:19 PM
1" 5/16
Posted 14 November 2010 - 09:43 PM
Posted 14 November 2010 - 09:48 PM
NO!
1 & 5/16". While the hub nuts are available as both metric and imperial the tower bolts are not. Neither is the larger steering wheel nut. A 34mm socket will fit over these and may turn many but it is not the right size and will cause damage. If you are going to work on the car, get the correct tools.
Posted 14 November 2010 - 09:53 PM
NO!
Yeah but the thing is can you buy 1 5/16" from a shop?
I used 34mm on the front subframe bolts and theres nothing wrong with them
Posted 14 November 2010 - 09:59 PM
Posted 14 November 2010 - 10:01 PM
Yes! I saw one in my local Halfords the other day.
