Hugh don't belittle yourself about trash cheapo repairs, mate if it works then there is nothing trash about it and it show ingenuity. Bloody good effort.
My Poor Wee Mini Sky
#991
Posted 15 June 2013 - 07:32 PM
#992
Posted 15 June 2013 - 07:38 PM
Looking good though buddy, keep it going
Trac
#993
Posted 15 June 2013 - 07:41 PM
Thanks Neil that is so kind. And Trac - you've got me worried now! Have I done another goof up? I used squeezy. Could I flush the worst out by easing the seal back. The thought of taking that windscreen out!! I have done so many bits more than once. What should I use?
Hugh
#994
Posted 15 June 2013 - 07:44 PM
Car shampoo would have done it Hugh.
#995
Thanks Neil! Sounds an easy solution. Always learning!
Hugh
#996
Posted 15 June 2013 - 07:47 PM
I'm sure it'll be fine because you used it in diluted form
Just done a little google and when fitting the front windscreen try and use talcum powder as a lubricant
Trac
#997
Mate everyone on here learns something new. None of us is perfect.
#998
Posted 15 June 2013 - 07:52 PM
Looks wonderful Hugh Nice repairs on the defogger elements and the back looks nearly perfect so far :)
#999
Posted 15 June 2013 - 07:53 PM
Trac
#1000
Posted 15 June 2013 - 09:32 PM
nearly full circle there Hugh, we are all learning and suggesting on here, summit you can never ask yr missus, all you get is "you and yr mini.....'s....," I do speak for myself of course Window looks ace now and what Neil says, car shampoo for yr next one. Good luck, yr doing great
#1001
Posted 01 July 2013 - 08:07 PM
Thanks again gents. Way down on page 7 means laziness.
Not much to show. Got one side window in. I started with car shampoo this time and a screwdriver. No chance. Actually damaged the seal. So I moved onto the string method and got the driver side in easy.
Do notice the gouges from the screwdriver failed method. Then with a touch of arrogance tried the other side 4 times and its still not in. But I've successfully damaged the headlining glue.
So I've given up at present. When my son comes home on holiday I'll get him to put pressure from the outside. He's a big strong fellow!
Made a rubber gasket from old inner tube for hand brake seal.
So it works. That's all I'm afraid.
Inching along, Hugh
Edited by hughJ, 01 July 2013 - 08:09 PM.
#1002
Posted 01 July 2013 - 08:26 PM
#1003
Posted 01 July 2013 - 08:31 PM
Glad to see your still progressing through this, would love to come and see it when both our cars are done!
Regards
Ben
#1004
Posted 02 July 2013 - 02:11 AM
Hats off to you Hugh. Been reading this all night. Its 3.10 am couldn't stop. Love the small detailed stuff you do. A true Celt.
#1005
Posted 02 July 2013 - 07:09 AM
Inching along very well Hugh, still slopping on paint here, will I ever catch you up
Graham
