* * * * * 2 votes
My Poor Wee Mini Sky
1146 replies to this topic
#961 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 27 April 2013 - 08:38 PM
Just sick of it
Have fitted steering column and mirror and sun visors.
And then caused a bit of a disaster. I'm getting ready, or I was, to fit the glass. But applying my double sided Mammoth tape, I put on too broad a layer. On trimming it back see what I did. I tried heating the glue but it just pulled the paint off. I'm useless.
You can see many attractive things in this picture - note first my orange peel paint; secondly, note the stripped off paint; thirdly note also the very attractive globs of glue protruding beyond the seal. I do hope you like it.
I think I'll just pack behind the rubber seal with silicon sealant and then sand back, mask and paint these areas. Its all more unnecessary work.
Sickening along, Hugh
Edited by hughJ, 27 April 2013 - 08:51 PM.
#962 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,022 posts
  • Name: Neil
Posted 27 April 2013 - 08:41 PM
Hugh chin up mate but DO NOT use silicone sealant. You will not be able to paint on it.
#963 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 27 April 2013 - 08:53 PM
Thanks Neil. I wasn't meaning to paint on the silicon but to keep it behind the seal. I'll see. I know you would take it all off and strip back and repaint,  but your a hero, I'm  a woose.
Hugh
#964 grahama
grahama
  • 2,442 posts
Posted 28 April 2013 - 08:01 AM
All was going sooo well Hugh,  shame this has happened.  I'm sure you will get it sorted though.  Why are you putting the tape behind the windscreen rubber,  is it just to hold it in place while window was fitted??   Just I didn't notice any on mine when I stripped it down.
Graham
#965 minimuk
minimuk
  • 1,946 posts
Posted 28 April 2013 - 12:04 PM
Hugh, we all have stunts like that, one step forward and 2 step's back, part of the play....at least you are open with it and tell us, you win in the end.
keep it going, I second the silicone bit what Neil said, silicone in never to be used on a mini......
Edited by minimuk, 28 April 2013 - 12:07 PM.
#966 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 29 April 2013 - 07:58 PM
Silicone causes rust. Use the correct windscreen sealer like these
http://www.ebay.co.u...cat=0&_from=R40
Plus the silicone will not just stay behind the rubber like you want. It will squeeze out onto the paint and WON'T come off enough to paint.
The paint blemishes are easily taken care of with a brush or spray. Sand first. It helps to pull the rubber out a bit so the new paint goes behind the rubber.
It's looking very good now :) Oh and the difference between your rebuild and mine is that I've been working slowly for nine years now.
Keep up the good work.
#967 Brams96
Brams96
  • 2,308 posts
Posted 03 May 2013 - 09:51 PM
Silicone sealant actually eats paint & causs damage. Dont use it.
#968 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 May 2013 - 06:15 PM
Not to mention more paint reactions than you can shake a stick at!
#969 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,135 posts
  • Name: Sean
Posted 04 May 2013 - 06:42 PM
Heres an old tip!!
If you're doing a repaint and can't be bothered to pull the windows.  The best way to avoid a masking line between the car and the window is to pack behind the seal with 3 core electric cable.
This lifts the seal clear of the body and all you need to do is fully mask the seal and then paint.  When the cable is removed it looks like you've never been there.
#970 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 04 May 2013 - 07:12 PM
Thanks all you gents for the advice. This fan of silicon sealant will leave it well alone.
Graham thanks. The tape has to be behind the rubber. That's how the headlining was original held on but by glue on the outside of the car behind the rubber. I am using a double sided tape instead of glue.
minimuk I always value what you advise.
Don thanks for the advice and the links to the windscreen sealant. Its my car had rusted behind the rubbers. They seem to have let water through so I want to have a belt and braces and maybe overtrousers!
Brams 96 and Adam thanks for the further comments.
Thanks Shifty, The glass still isn't in so I can do a quick mask and paint.
Its still little bits
Changed this
To this - the back view is for reference incase anyone needs it
Which now looks like this
Now I have had that dash in and out a few times now. The sticky back plastic and cardboard are all kind of creased now. I had to take it all out again to get the radio housing in!! The bolts go in from above!
And I've got a carb again
There's a new filter in there
Still need to paint the thermostat air intake.
And I could clean my windscreen if I had one
Will this old bus ever run again?
Still creeping along, Hugh
#971 ToM 2012
ToM 2012
  • 4,066 posts
Posted 04 May 2013 - 07:17 PM
looking really nice hugh love that center part how did you do it? cheers tom
#972 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 04 May 2013 - 07:24 PM
Hi Tom thanks. It is decals from Sticky Fingers - http://martincull.create.net/ - he is very helpful and did this colours specially for me at no extra cost.
Hugh
Edited by hughJ, 04 May 2013 - 07:24 PM.
#973 Carlos W
Carlos W
  • 10,114 posts
Posted 04 May 2013 - 07:34 PM
Once it's finished are you going to tour the country visiting TMF members?
#974 ToM 2012
ToM 2012
  • 4,066 posts
Posted 04 May 2013 - 08:01 PM
Hugh
cheers mate just messaged him
#975 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
He had better venture across the border as I'd love to put this car on a TMF stand.
