My Poor Wee Mini Sky
#946
Posted 27 March 2013 - 06:50 PM
#947
Posted 27 March 2013 - 09:35 PM
#948
Posted 01 April 2013 - 11:48 AM
You will soon be zooming around the lanes of Scotland and it would have been all worth it !!
Onto the next project ??
#949
Posted 11 April 2013 - 06:17 PM
I've been on holiday to the Yorkshire Dales again - just love it. I'm back and not getting into it. I removed the rear glue for the headlining to see if I could improve. This Mammoth tape is good. It goes on easy and comes off easy. The headlining peeled off and than I heated the glue strip with a hair drier and pulled - came off no problem. I had put that off for a while!
I then tried packing bits of foam above the bars and re-glued it at the back. Will need to get more tape. The headlining is still as bad. I am just going to thole it. Maybe some years on I might have another go. I just don't have it. I'll put the glass in and not look at the roof!
I'm working on the brake master cylinder
I have to repair the terminal on the fluid level indicator sender. Any ideas where I could get some springy brass/copper type sheeting to make a terminal?
Its a poor show, I know.
Hugh
Edited by hughJ, 11 April 2013 - 06:18 PM.
#950
Posted 11 April 2013 - 07:42 PM
Andrew
#951
Posted 12 April 2013 - 06:44 AM
But rather than messing around it'll be easier to just buy a new cap,
Keep going Hugh
Trac
#952
Posted 12 April 2013 - 12:15 PM
#953
Posted 12 April 2013 - 03:22 PM
#954
Posted 12 April 2013 - 06:30 PM
Today - pathetic - at least all the brake parts are now in place
That's it!! Braking along, Hugh
#955
Posted 12 April 2013 - 08:16 PM
#956
Posted 12 April 2013 - 08:38 PM
Been secretly checking up on this for the last few months and it is coming along nicely! Just noticed you were talking about the rubber backed sound deadening? i have some if you want them as freebies (well postage charge) if you wanted them? will clear up the shed a little :)
Keep up the excellent work!
Paul
#957
Posted 13 April 2013 - 08:52 PM
#958
Posted 13 April 2013 - 10:03 PM
#959
Posted 16 April 2013 - 06:34 AM
Yorkshire Dales sure is a pretty part of the country. You're lucky to live so close.
#960
Posted 20 April 2013 - 08:46 PM
Mine hasn't been too careful. I've put the Blue Peter dashboard back in. Its made from cardboard and sticky backed plastic. The Mini's trim is really rubbish. I had to put in and out several times before got it sort of right!
All that mess that needs hoovered up is from the rubber backed sound insulation. More rubbish that the Mini is made from. I had a problem with the left side air vent. Too close to the dashrail. I presume I got something wrong when welding in the flitch panel. Never mind.
Still crawling along, Hugh
