* * * * * 2 votes
My Poor Wee Mini Sky
1146 replies to this topic
#916 Marco1972
Marco1972
  • 822 posts
Posted 17 February 2013 - 05:00 PM
Looking good Hugh
The end is in sight .......
Keep up the good work..
#917 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 18 February 2013 - 05:17 AM
holy crap. my hat goes off to you Hugh. Have just read this entire thread and you are my inspiration! I have a '71 Australian mini I'm just starting to work on, novice welder, novice everything really, so it makes my day to see that not only skilled panel beaters/mechanics can have a go and be successful!
Also my hat goes off to Grahama.. only half way through your thread though!!!
#918 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 18 February 2013 - 08:34 PM
Graham I think rust is an impossibility - you can't get away from it.
Darren thanks - is it not the ballast resistor that works with the coil?
Trac I use Hammerite quite a bit - I find it chips awful easy. But I did paint the callipers, mind you not with Hammerite.
Marco1972 - thanks, wish it was good work!
sixtyeight - is that a message from Australia? Great! I do thank you. Do read Graham's page. I think his is about the best.
Just little bitties
Wee bit of paint round the alternator
And the clutch slave cylinder. Back below zero outside. I took it in as the paint went a slightly matt finish! Longing for the Spring. Saturday and Sunday were just wonderful here.
Cleaned alternator fittings
And put the coil back
And cleaning the ballast resistor plate
All moves it a little on its way.
Moving slowly along, Hugh
Edited by hughJ, 18 February 2013 - 08:35 PM.
#919 grahama
grahama
  • 2,442 posts
Posted 18 February 2013 - 08:38 PM
Hugh,
cleaning nuts and bolts !! you have changed Hugh, it is going to be concours now I see, looking good as always,
Graham
#920 sixtyeight
sixtyeight
  • 630 posts
Posted 19 February 2013 - 08:28 AM
Hi Hugh,
certainly is a message from Australia :)
this is my little mini, http://forums.minidr...ini-k/?tab=main
she's a 1971 Australian made Mini K. Has a few things on it quite unique to Australian cars, being 1/4 windows on the doors, external hinges on a late model car, door handles from a late model Australian Clubman amongst others! Have cut the front wings off to be replaced, and patched up one of the several rust holes!
Tim.
#921 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 19 February 2013 - 09:25 PM
Graham you know I always follow your example!!
Tim that is so nice and so unusual! All the best with it. I'm sure you'll have to patch more than several rust holes!
Freezing out in garage tonight. Found it had gone to -5 last night! Tim you be grateful for your climate!
Just a few little jobs
I at last fitted these wretched little bump stops (red ones!).
And the alternator is in
And the clutch slave cylinder. Will have to rebuild the master now.
Derusting and painting one or two little bits as well. She's back on her front wheels again.
Moving along, Hugh
#922 minimuk
minimuk
  • 1,946 posts
Posted 19 February 2013 - 09:47 PM
It's gonna be one of the most colourfull mini's around at this rate, you are getting closer ;D
#923 ZEBERDEE
ZEBERDEE
  • 110 posts
  • Local Club: Box Hill Mini Club
Posted 20 February 2013 - 06:06 PM
Cant wait to see it all finished :) keep up the good work Hugh
#924 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 23 February 2013 - 07:58 PM
minimuk you've got to have a bit of colour in your life! ZEBERDEE I just can't wait to see it all finished. I'm wearying!
Keeping the little jobs going
Going to clean up the starter and brake compensator.
Still using up that ole' tin of blue Hammerite!
The ballast resistor cleaned up a wee bit. It's fitted but no photo
Then tackled a job I started 8 years ago. The wipers didn't work when I took it up from Edinburgh on a very wet January 1st. I got them going in a sort of a way cleaning up contacts and I fitted a new parking switch. Then I tinned the wires to fit a new plug to the loom and stopped!! That's where I stopped 8 years ago. I got it fitted today!
Soldered the wires together with heat shrink sleeving ready to slide over the joins.
Sleeving shrunk in place
And the loom taped up
And connected
Try cleaning this now
Just a little, will do more next week
Put this for the brakes back together, had painted it several months ago
And today's big disaster! Or hughJism. I went to fit the bonnet hinges properly with nylon washers at each side of the hinge. Got the drivers side after a while - getting it all lined up and the bolt through is a nightmare. But really struggled on the passenger side with the wiper motor in place. I was using a wee screwdriver to try and get all the holes lined when I dropped it. It fell just above the steering rack. I then clumsily trying to get hold of it made it drop just on top of the steering rack. I could feel it with my fingers and almost got it. But then I pushed it somewhere I don't know. I've jacked it back up, taken the wheels off, have hunted high and low, used a probe with a magnet, head torch, altogether wasted far too much time and I can't find it! I am not going to take it all apart to get it out but I don't like thinking it is lurking somewhere! But that's me.
Fooling along, Hugh
Edited by hughJ, 23 February 2013 - 08:02 PM.
#925 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,021 posts
Posted 23 February 2013 - 08:06 PM
Coming along nicely Hugh, If you drop Something in the engine bay it's gone forever :lol:
#926 grahama
grahama
  • 2,442 posts
Posted 23 February 2013 - 09:07 PM
Bugger!!! Going so well Hugh , damn little washer thingies .
#927 hoody99
hoody99
  • 699 posts
Posted 23 February 2013 - 09:59 PM
When you start her up it will probably vibrate loose and fall on the floor at which point you won't need it just like everything else lol
#928 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 24 February 2013 - 12:39 AM
I bet it's gone through the hole in the steering rack mounting bracket. That's going to rattle really annoyingly!
Progress is looking fantastic as always Hugh :-). Do you want to finish mine when you're done? :shifty:
#929 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 24 February 2013 - 07:47 PM
Looking good as always, I dread to think about the amounts of bolts that I have dropped down by the diff.
What's next after you've finished the ancillaries then ?
Andrew.
#930 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 25 February 2013 - 08:59 PM
Looking good. That bracket will be stuck between the subframe and the bulkhead above the steering rack is my guess.
