* * * * * 2 votes
My Poor Wee Mini Sky
1146 replies to this topic
#886 Mini-Mad-Craig
Posted 05 January 2013 - 07:50 PM
Can you use a hairdryer or heat gun and a squeegee or credit card (you must have a few of those to have come this far ;D) to iron the creases out? just be careful not too distort or stretch it too much because I think the material is almost a vinyl?
I'm sure a little more patience and it will be perfect :) It will be rewarding to put the seal back over to cover knowing its all done!
#887 grahama
grahama
  • 2,442 posts
Posted 05 January 2013 - 08:57 PM
Hugh,
admitedly a little rumpled in the corners but not a bad job at all. I have mine to do with the original lining, if it has survived the two/three years !! If not then may well be fleabay to the rescue. I am looking forward to it to be honest as it means I will be nearly there, a feeling I just can't see at present. Still we plod on Hugh, and if mine comes out as good and useable as yours I will be chuffed.
Graham
#888 Marco1972
Marco1972
  • 822 posts
Posted 06 January 2013 - 05:30 PM
Hi Hugh
Nice job mate I know those things are a bloody nightmare as I used to fit them at longbridge back in the day we just used to run glue around the window edges and door frames ect the stretch glue and trim all good fun ( not !! )
Keep up the great work I've spent the weekend cutting off my oversill what a shock I hate rust !!
#889 Minidarren83
Minidarren83
  • 1,207 posts
Posted 06 January 2013 - 07:05 PM
It's coming along very nicely now hugh its a shame about the painted parts that went bad but not your fault and the headlining is not a bad job I'm sure it would shrink with a little heat. this year is your year not much left to do and you will be flying around before you know it
Keep up the good work darren
#890 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 06 January 2013 - 08:49 PM
Seems like you said that the back two rods have twisted. Getting them to sit right would mean equal tension front and back. Looks like the rear has slipped a bit allowing the rods to roll forward. Try pulling the lining a bit tighter back while lifting the rods.
Don't you just love hydrated paint. It cools while drying, attracting humidity - but then it looks "cool" afterwards. If only you were the first to do that O_O
Still; looking good
#891 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 07 January 2013 - 08:40 AM
Headlining looking good Hugh. To get the last creases out I gently used a heat gun. I set up the tension on the edges the best I could to pull the crease out. Then wafted the heat gun over the creased area. The creases relax in the heat. The tension that has been set up pulls it tight. It then cools in that shape. The heat gun became my best friend for this job.It was the only way I could get a 2D sheet to fit a 3D shape.
Edited by jagman.2003, 07 January 2013 - 08:40 AM.
#892 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 02 February 2013 - 09:58 PM
Static!
Tom, Craig, Graham, Marco1972, Don and jagman.2003 thank you for comments and advice. Oh dear. I found my topic down on page 8!! I have kind of stopped. The headlining has taken the heart out of me. Aragorn, in Lord of the Rings, said we should not have the heart taken from us! I will try peeling it off at the back and try and get the bars upright and a bit more tension. The weather has been too cold to try it. I have bought a used radiator and am hoping to pop the engine in soon.
The only reason I am here is for advice. Do you put the engine back in with the radiator attached?? Hope one of you experts can point me in the right direction. I took the radiator off when taking it out.
Sorry nothing to report
Hugh
#893 grahama
grahama
  • 2,442 posts
Posted 02 February 2013 - 10:11 PM
Nice to hear from you Hugh,
no idea where my thread is at the moment, too wet and cold to be lugging my engine out for testing so down the pages I will remain lol. The Spring will be here soon and mini progress will start again !!
Graham
#894 racingenglishcars
racingenglishcars
  • 293 posts
Posted 06 February 2013 - 03:32 PM
I'm sure there's a lot of different opinions on how to install the engine / radiator. I have put them in together. Some say that when the engine is in, to put the bottom hose on the radiator then drop it in. Either way it's a tight fit.
#895 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 06 February 2013 - 06:23 PM
Thanks Don for that .- think I'm going to have a go with radiator on - to avoid contortions. Still have to get the engine mount bolts on though!
Yes Graham - looking forward to the Spring!
Hugh
Edited by hughJ, 06 February 2013 - 06:24 PM.
#896 minimuk
minimuk
  • 1,946 posts
Posted 06 February 2013 - 11:01 PM
Aragon, Lord of the rings, Star-trek whatever next, looks good Hugh, first headlining is always a pain, but you won the battle. Nearly there.......your coming down to the MITP 2013 for sure.....
Edited by minimuk, 06 February 2013 - 11:02 PM.
#897 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 09 February 2013 - 07:38 PM
Hi minimuk thanks. I don't know but I think I'm too timid to leave the north of Scotland! The headlining is needing a rethink.
Well I've been pathetic, really pathetic. But I have put the engine back in.
So some more bits ready for action
And then today heaved the engine in.
Fitted with a second hand radiator off Ebay.
So two years and three months later
And in place. The lowering in went OK. Snagged on the exhaust but easily sorted. What did waste the time was the rear drivers (right) side engine mounting bolt. Who thought that one out!! It took an hour to line up the hole and feed the bolt in!
So I am pleased to have that done. I will get the drive shafts fitted next week and start on the starter, alternator and carb. Then will have to get the wiring sorted out.
Refitting along, Hugh
#898 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 09 February 2013 - 07:43 PM
Engines looking great Hugh, it'll be no time at all until you've got it up and running again.
Andrew
#899 ToM 2012
ToM 2012
  • 4,066 posts
Posted 09 February 2013 - 07:55 PM
you are getting there hugh and doing a brilliant job! and the bolts are a pain took me about the same time to just get the left side mount bolted. trying to hold the bolt in while putting a washer on then the nut and then it drops off! what a pain! soon be driving it.
#900 Miniowner123
Miniowner123
  • 987 posts
Posted 09 February 2013 - 09:16 PM
coming along nicely Hugh, engine mounts can be a pain in the back side so you've done well if it was only one bolt causing an issue :-)
    Bing (1)
