My Poor Wee Mini Sky
#871
Posted 29 December 2012 - 09:41 AM
#872
Posted 29 December 2012 - 09:45 AM
All looking good Hugh. It's so much nice putting clean shiny parts back on the mini, so different to when we stripped them, full of crud and oil. Clean hands all the way to the key turn now my man !!
Or cotton gloves!
#873
Posted 30 December 2012 - 08:28 PM
I'm sure you know where all those engine brackets go. I don't think I recognise all of them.
Pretty soon you will have the engine in and running. That will be the day!
I hope you can get a helper sometimes. I find it difficult to do a lot of these jobs alone.
#874
Posted 01 January 2013 - 09:36 PM
Jordie - thanks for trying to get me to do that headlining!! I will have to force myself.
Graham - hands are still filthy!
Carlos - maybe rubber gloves - probably sweat too much!
Don - you can admire me going to the cold garage, but not the thorough rebuild. Some bits are pretty dodgy.
I do thank you all for the encouragement - it does help. I did say at the start of this topic that I was putting it up to force me to keep going. If I stopped now I'd be too shamed!!
Still messing about with the engine
More fittings being cleaned and painted
Its never-ending!
I have got the distributor back together and the points re-gapped and the engine re-timed (statically for the moment, probably good enough anyway). I did the valve clearances - what a smashing engine to do that job on. No fancy tools, easy access and the exhaust and inlet both the same gap!! Lovely. Fitted new plugs and oil filter.
So we are heading the right direction but slowly.
Moving along (slowly), Hugh
#875
Posted 01 January 2013 - 09:37 PM
#876
Posted 02 January 2013 - 11:15 AM
I recently joined this forum and I have spent the last 3 days reading your thread really fantastic work takes me back to when I built my first mini all those years ago still having therapy for it lol.....
Keep up the good work.
Mark..
#877
Posted 02 January 2013 - 01:03 PM
#878
Posted 02 January 2013 - 03:50 PM
#879
Posted 04 January 2013 - 04:39 PM
Don - a very good new year to you.
jagman.2003 - a very good new year to you. I do hope it is the year of finishing!!
Mark - I do appreciate your kind remarks and a very good new year to you.
Neil - a very good new year to you. I have always value whatever you say. You are the one that got me going. I had hoped to see you finished as you do such fantastic work.
Cleaning and de-rusting radiator cowl
And had a disaster. The weather is miles milder and condensation is forming on everything in my garage.
This has happened to some parts I painted
Its one of these annoying things that hits the stupid Mini restorer.
I decided to make a start on the headlining as the weather is mild so I got a couple of heaters going in the garage. Its the first time sweating in the garage for a long time!! I fitted the new headlining rod to replace the one I broke and tensioned the lining. I also washed the old seals and put them roughly in place
And then went to try my Mammoth Tape!!
It is easy to use but its too wide so I'm cutting it up the middle - that makes it a bit trickier.
So I've fixed it front and back
So I'll let that settle 24 hours. I had a wee bash trying to look at the sides and round the pillars - that doesn't look like fun.
Lining along, Hugh
Edited by hughJ, 04 January 2013 - 04:54 PM.
#880
Posted 04 January 2013 - 04:58 PM
Do you have any particular advice on doing the headlining as everyone says its very tricky, and as I will be fitting mine very soon I need all the help I can get.
Keep up the work anyway
Andrew.
#881
Posted 04 January 2013 - 06:14 PM
Have you tried painting your smaller bits in the loft at all. This is where I am doing mine at mo, no extra insulation but no condensation. Just a thought.
Graham
#882
Posted 05 January 2013 - 06:42 PM
Andrew - if you can get anyone else to do it that's what to do. It's an awful job.
Graham - that sounds wise. My attic is so full of rubbish stuff that I think that would be impossible.
I did the sides today of the headlining - a Hugh job - not quite right.
I knew I would do it wrong. Its rumpled - I can live with that. But the rear two support bars have turned about 90 degrees. Or, rather, I didn't notice and got it tensioned wrong. But its giving the rear a sort of flat look. That's just me. I'm leaving it at present. May try fitting another in a few years! If I try it again though it could be even worse. Take my advice - don't do it.
I will say the jagman.2003's advice is spot on - using double sided tape is good. Dear knows what I'd have done with glue.
Back to work on Monday. Not happy with my holiday's progress.
Sickening along, Hugh
#883
Posted 05 January 2013 - 06:45 PM
How much did you pay for it dare I ask?
Nice work on the whole car. I've always followed this thread and the quality is always top notch :) You must be seeing the light now?
#884
Posted 05 January 2013 - 06:50 PM
I actually wish I was back welding after that job!
Hugh
#885
Posted 05 January 2013 - 07:46 PM
14 user(s) are reading this topic
0 members, 14 guests, 0 anonymous users
