My Poor Wee Mini Sky
#706
Posted 03 July 2012 - 08:27 PM
#707
Posted 03 July 2012 - 10:05 PM
#708
Posted 04 July 2012 - 07:08 AM
#709
Posted 04 July 2012 - 09:21 AM
Chris
#710
Posted 04 July 2012 - 10:41 AM
Dont rush the filler, if you're not happy with it now then it will look a hundred times worse when the paint is on.
Treat yourself to a tub of fantastic and have another crack at it.
If you're trying to fill a large area and are struggling to get it flat use a long steel ruler instead of the small plastic applicator. That will level the filler to the surrounding metal. All you need to do then is blend it in.
#711
Posted 06 July 2012 - 08:21 AM
on hols in torrential rain conditions near Holmfirth so thought I'd sneak a look on TMF without Jan bollocking me for not taking her out !!
Overall it looks good from here !! I know from my poor efforts that close up you see all the little imperfections and I am going to slap some more filler on the bonnet edge even after two hours of sanding. Boy do I hate sanding, DA sander at home now hopefully !!
I too get very naffed off with it all, especially being outside and not being able to do things for days on end, and then looking at the stonechip to see reactions !! Very frustrating but you have to persevere and re do it !! I thought about leaving it and slapping paint and clear waxoil on it but it wouldn't last.
As Shifty says you will probably regret it later on if you don't re-visit the areas that bother you but it is your mini and your choice and I will be behind you either way. Looking forward to more green too lol !!
Graham
#712
Posted 06 July 2012 - 08:41 AM
Oh yeah, it's looking quite straight, from here but you be the judge.
Cheers, Donn.
Edited by racingenglishcars, 06 July 2012 - 01:40 PM.
#713
Posted 09 July 2012 - 04:21 PM
I fitted the seam strips sealing them as I went. I painted the seams with etch and top coat and also did inside the seams the same way. These were unprimed from minispares.com.
I than tidied them up sanding back excess sealant, etch priming etc. I have now given the whole car a coat of high build primer. This has shown up areas needing a bit more attention and little bits of paint reaction. This is where it meets the Rustoleum Combicolor or where I had put stopper. I am wiser, now - a bit late.
This has certainly improved its looks - all being one colour. I'll probably not be back for a wee while as I'll be sanding and filling a bit more. Its a job I detest!!
Creeping along
Hugh
Edited by hughJ, 09 July 2012 - 06:26 PM.
#714
Posted 09 July 2012 - 04:27 PM
#715
Posted 09 July 2012 - 05:04 PM
#716
Posted 09 July 2012 - 07:12 PM
you sound a bit more up beat !!
Graham
#717
Posted 09 July 2012 - 07:55 PM
Chris
#718
Posted 09 July 2012 - 08:14 PM
What did you use to seal the seam finishers ?
Andrew
#719
Posted 10 July 2012 - 10:09 AM
Hugh
#720
Posted 10 July 2012 - 11:41 AM
Bing (1)
