My Poor Wee Mini Sky
#676
Posted 07 May 2012 - 10:56 PM
from your first weld to you last what a diffrence that is a pro weld there bud :)
#677
Posted 08 May 2012 - 07:18 AM
#678
Posted 10 May 2012 - 11:36 AM
I purchased a rather small bottle for my mig. It's expensive, but it retains it's value as it is always traded for a replacement, x-ray'ed bottle upon refilling. And, then I will always be welding something, like my colleague's chairs, a tool for roof tiles, another Mini, Land Rover or something like that.
You, Hugh have after all turned into a rather decent welder. There might be a retirement profession for you if you don't look out.
#679
Posted 10 May 2012 - 11:57 AM
you have come a long way from the beginning of this build, will you be painting it yourself?
as for the clogging up of the paper while sanding down that filler http://www.refinishs...ultihole-Blocks
the 3M ones are expensive but you can get cheaper ones, they can be hooked up to a hoover or summin so it extracts all that dust and helps it not get clogged up, altough most of the time i use it without the extraction ahha!
looking forward to seeing this completed!
#680
Posted 12 May 2012 - 08:00 PM
Thanks Shifty - I've just taken the reacted area back to bare metal.
Graham - I've just taken the reacted paint off - a mixture of Rustoleum Combicolor and Rustoleum Hard Hat and it took some doing. I impressed myself with how well I got the paint to adhere. I've done a lot worse in the past!
Thank you tommypope!!
jagman.2003 as usual a comment from you is highly valued! Yours is a fantastic rebuild.
racingenglishcars - purchasing sounds a good idea - I never looked into that and just rented. It would be great to permanently have a gas bottle! Thanks for your very kind comment.
JonnyBMX - thank you and thanks for the help - that looks pretty good - at the moment I am cash strapped! So have bought nothing for the Mini for the past month!
Just putting on thin layers of filler and sanding back with clogged up emery paper. Also folded the lips of the A panels and sealed. And as said above took reacted paint off one side.
All very boring - just an hour to an hour and a half each day.
Creeping along
Hugh
Edited by hughJ, 12 May 2012 - 08:01 PM.
#681
Posted 12 May 2012 - 08:42 PM
showing me techniques for when I get to where you are. Despite your claims to be anything other than a rank amateur at this, you are doing a more and more professional job, allbeit with some set backs !!!
Keep it up,
Graham
ps is the filler over bare metal or well rubbed down e coat / paint??
#682
Posted 13 May 2012 - 01:11 PM
Looking good sir! Looking forward to applyng some paint? I'm dreading mine haha.
#683
Posted 16 May 2012 - 08:59 AM
One question- what is the roller paint finish like? I hope it looks good, it would seem a waste to put lumpy paint on after your hard work. Surely if you do all the prep and just pay someone to spray it wouldn't be too dare?
#684
Posted 16 May 2012 - 10:02 PM
#685
Posted 17 May 2012 - 10:38 AM
#686
Posted 19 May 2012 - 08:49 PM
Deathrow thanks - you are my mentor. I know you have a lot to do looking after this website. But yours is superb work - I'd love to see you finish before me yet!
CobraV8 thank you. I'm not rollering it now I would have liked to. I've moved onto a paint called Rustoleum Hard Hat and I'm rattle canning it!!! I'm a Scotsman!!
ZEBERDEE thank you.
deebo - I'm just using Isopon filler. In fact I'm using too old tins that have sat in my garage for donkeys. I also use a little knifing putty for the final filling of little scratches and bubbles.
Not much to show - still building up thin layers of filler and sanding back. It is boring painstaking work!!
Took my Mini out in the sunshine so I could give my garage a cleanout. Its first time in the fresh air for a long time!
The coachlining on the driver's side is away!
But I've had a disaster. I use the Linux operating system and am always dabbling and messing. Yep formatted my home partition. Lost all my Mini photos so great they are mostly all here though at lower resolution!! Just me!
Losing it
Hugh
Edited by hughJ, 19 May 2012 - 08:50 PM.
#687
Posted 19 May 2012 - 09:08 PM
I'd love to be as far on as you, and hopefully I will be by the end of the year, unfortunately I had a major set back last year, but I'm over that now!
#688
Posted 19 May 2012 - 11:15 PM
And really jealous your mini is on it's wheels! Looks very good Hugh :)
Chris
#689
Posted 20 May 2012 - 06:54 AM
I can't offer any explicit technical help as I don't use Linux anymore, try Googling for a tool, it won't be that easy though! This is why I have automated backups
#690
Posted 20 May 2012 - 07:45 AM
that mini looks the nuts pal, first real look at it in full, very nice indeed. You should be very pleased with yourself!! Not long to go before the refit .
I have a couple of tecky friends and will ask about the drive.
Graham
Bing (2)
