My Poor Wee Mini Sky
#601
Posted 20 March 2012 - 06:23 AM
I'm sure you will pull it off without a hitch. Your welding is really quite good now.
#602
Posted 20 March 2012 - 11:04 AM
#603
Posted 20 March 2012 - 06:11 PM
dom
#604
Posted 20 March 2012 - 07:14 PM
looking great hugh. are you gonna cut the bonnet and extend it in the middle or have i got the wrong idea? lol
dom
If he is going to follow the technique i used on Project Erm then you slice each side of the bonnet and add a thin strip of steel. Try to add it to the middle would be a real pain plus with the ridge in the middle would compound matters even more.
#605
Posted 20 March 2012 - 09:49 PM
So tackled the right side - slit up the side of the bonnet and cut this wee bit
Tacked and checked gap
And welded - took quite a while
And ground back
But here we go - hate grinding, always go too far
Some holes to fill - another day!
The gap is better. A bit of filler and it will not be too revolting.
Moving along
Hugh
#606
Posted 20 March 2012 - 09:56 PM
Coming along nicely though !
Graham
#607
Posted 23 March 2012 - 09:18 PM
I've done the right side of the bonnet last night and tonight - just the same as the other side. It needed a slightly wider and longer filler piece. Here the edge of the bonnet has been cut and the filler piece.
I hate grinding back my welds. I'm going to have to redo bits like I did on the other side. I wish I was like Scott or minimuk - they seem to use weld like filler and get it to grind back to like it was all the original metal. I can't. But my old friend Isopon will help me out.
I have to deal with the rear of the bonnet - I've just left the strip sticking back at present. Will this welding ever end? I thought I was just about there. I have enjoyed doing these long welds though.
Welding along
Hugh
#608
Posted 23 March 2012 - 10:19 PM
#609
Posted 23 March 2012 - 10:24 PM
#610
Posted 23 March 2012 - 10:31 PM
Same here, like Scott filler is needed one way or another sometimes, and the more practise you have the better you get at it.
not bad your extensions, I would have taken the bonnet off after 5 or 6 tacks to have those strips in position, then I would welded it from under the bonnet(engine side), then turned it over and would give the cut opening a very thin straight weld 1" and 1" space and so on, from one end to the other, then go back to beginning and weld in between those first welds, only after that I would use a 80 grit flap disk to start sanding those welds back, on both sides of bonnet and use a fleece disk to sand it smooth with a light pressure(Cheers Danny),...and little pits left after that tack those and sand back again.
this area you are doing is not easy to work on so your resuld is not bad at all. what is your welder setting, it looks like the wire speed might be a little to fast, or is it good for you?
Edited by minimuk, 23 March 2012 - 10:34 PM.
#611
Posted 24 March 2012 - 07:21 AM
I'd be apprehensive slitting and welding a strip an outer panel in case I distorted it with too much heat. Hopefully I'll get round to the front on mine one day to find out.
Looking good.
Adam
#612
Posted 24 March 2012 - 06:22 PM
Worth all the agri now, soon be in paint. Your bonnet may well need a skim of filler, but wait till u see the scruffy repair I did today, I may need a bucket full. Looks like you are finding your feet nicely with the intricate welding, where as I am only finding myself going backwards in finesse !!
Keep it up
Graham
#613
Posted 24 March 2012 - 10:09 PM
I ve just read the whole thread. Simply enthralling reading, from being worried about taking the grinder to the mini, learning to weld and then fabricating parts and problem solving. You keep saying it is only for MOT, buy it all looks really good so far and at a very high standard. You must be proud when you have a look at what you have done.
Thanks for documenting everything so thoroughly I have found it inspirational reading.
Cheers!!
#614
Posted 24 March 2012 - 10:14 PM
#615
Posted 24 March 2012 - 11:13 PM
