* * * * * 2 votes
My Poor Wee Mini Sky
1146 replies to this topic
#391 CLM
CLM
  • 817 posts
Posted 20 November 2011 - 01:46 AM
I've been lurking and watching, things look like they are going well there Hugh, it shouldnt be too long before you have that shell done :)
Chris
#392 johnsn
johnsn
  • Just Joined
  • 69 posts
  • Local Club: OMS
Posted 20 November 2011 - 07:07 PM
Hi,
If you put a lamp or some kind of light in the boot, it will worm the sheet metal and the paint will harden.
Don't get it too hot, or you'll bubble the paint. Just put a small light in the boot and close it up as much as you can.
This will make a worm box that you can paint the outside and the inside. In fact you can pre worm the boot to check it's not too hot.
You can do this to the whole car. It just takes more lights.
Try it, you'll like it. ;D
john :D :D
Edited by johnsn, 20 November 2011 - 07:08 PM.
#393 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 25 November 2011 - 01:29 PM
looking good! roll on christmas!
#394 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 26 November 2011 - 03:57 PM
Thanks for advice and nice words Deathrow, Chris, John and JohnnyBMX.
That sounds like a great idea, John. Thanks.
At present the weather is still mildish, just a couple of nights of frost so I am trying to get paint on and protect. I moved to the front - wire brushed with the grinder, Kurust on and cleaned, Etch primer on, Seam sealant along seams and welds, five coats of Hammerite Stonechip Shield, and today a coat of green Rustoleum. I haven't taken photos of the process - its extremely dull.
Here is how it looks now. I'll let the paint have a bit of time to harden and put on another coat. Its all brushed on as nobody will really see these areas. Well I brush painted a whole Astra once so I'm mot the fussy sort!
So still moving on a wee bit. It's getting the areas where the subframes are going done.
I've also been wire brushing bits and pieces from the radius arms.
What a difference from the weather this time last year. It was Baltic in the garage. Its not too bad just now.
Inching along
Hugh
#395 Carlos W
Carlos W
  • 10,114 posts
Posted 26 November 2011 - 04:01 PM
Hugh, just to confirm, did you do etch primer, then seam sealer, then stone chip?
It's looking great!
Carlos
#396 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 26 November 2011 - 04:09 PM
Yes Carlos, that's the order. If you look back in my topic you will see that the very wise ones on the forum like panelbeaterpeter and Neil both emphatically emphasised this.
This is what panelbeaterpeter said - "Regarding the stonechip, DON'T apply it over paint. Etch prime very lightly, then stonechip, then paint. You can prime before paint if you wish."
Thanks Carlos
Hugh
Edited by hughJ, 26 November 2011 - 04:11 PM.
#397 Carlos W
Carlos W
  • 10,114 posts
Posted 26 November 2011 - 04:10 PM
Noted!
I spent the day cleaning the bottom of mine with a wire wheel on the drill, ended up covered in ****
#398 087dave
087dave
  • 952 posts
Posted 26 November 2011 - 04:20 PM
Going along nicely hugh keep it up
#399 grahama
grahama
  • 2,442 posts
Posted 26 November 2011 - 06:51 PM
mmmmmmmmmmmmmmmmm green !!!! Stop painting it is making mine look sad lol
Edited by grahama, 26 November 2011 - 06:51 PM.
#400 Carlos W
Carlos W
  • 10,114 posts
Posted 26 November 2011 - 06:52 PM
You should see my car, it's MONTHS behind both of yours!
#401 johnsn
johnsn
  • Just Joined
  • 69 posts
  • Local Club: OMS
Posted 26 November 2011 - 07:05 PM
Hugh
You're welcome.
My garage got so cold paint stripper wouldn't work. I had to put two of those quarts halogen lamps under the panel to warm it up. Then it worked just fine.
See the attachments.
john :D :D
Edited by johnsn, 26 November 2011 - 07:06 PM.
#402 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 03 December 2011 - 04:12 PM
Thanks John. A wise man!
Thanks Graham, Carlos and Dave.
Just cleaning and painting. Preferring it to welding. Ignore the runs, etc. Its me! I feel I'm rounding a corner now.
I took my radius arms inside for a few days after Kurusting and running out of etch primer
But have now dealt with them
And bits and pieces
I'm not renewing everything just servicing and tidying up. If it works keep it! This is going to be my transport and not a hobby for driving on sunny days and showing.
Every little helps
Painting along
Hugh
#403 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 03 December 2011 - 04:19 PM
Progress looks good Hugh!
I did the same, took a break from the welding and did some scrubbing, cleaning and painting. It's a nice change for a while.
#404 Carlos W
Carlos W
  • 10,114 posts
Posted 03 December 2011 - 05:53 PM
I'm not replacing everything Hugh, brake plates and drums are fine so they will be getting cleaned up and painted!
It's all looking good!
#405 minimuk
minimuk
  • 1,946 posts
Posted 03 December 2011 - 07:15 PM
Impressive work there Hugh, like your fiddly jobs and nice radious arms,.... that green,... is the whole car going to be that green :shifty: ??
