My Poor Wee Mini Sky
#361
Posted 29 October 2011 - 10:12 PM
I agree, those roof gutter repairs are hard. I have had to do a few on mine, but as I have to replace the roof, I have only had to do the lower lip. What we did to my first mini is, before painting the roof, go around gutter with seam sealer and smooth to shape of gutter with your little finger or a piece of tube. Gives a nice finish and seals it too.
Great work Hugh, keep it up.
#362
Posted 30 October 2011 - 11:14 AM
#363
Posted 30 October 2011 - 11:53 AM
#364
Posted 31 October 2011 - 09:49 PM
Just a wee bit tonight. Kurust on the rear wheel arches and then acid etch primer.
And started cleaning at the front.
So every little helps. Anyone else notice how the wire cup brush converts seam sealant into 'cobwebs'?
Cleaning along
Hugh
#365
Posted 31 October 2011 - 10:26 PM
Adam
#366
Posted 31 October 2011 - 11:34 PM
#367
Posted 01 November 2011 - 06:52 PM
Graham
#368
Posted 02 November 2011 - 06:22 AM
#369
Posted 05 November 2011 - 04:29 PM
I got three more cans of Hammerite Stonechip Shield on. Three coats on the main underside and there are two coats under the boot. I'll get another three cans and that will make it five coats and eight tins of the stuff. Hope that's enough. The weather is much colder with frost this morning. I have some transparent sheets on the garage roof to let light in. I wish I'd never put them on. The condensation and drips that come off them. It doesn't help the Mini!
I've freed most of the bolts on the rear subframe but I think the subframe is trash.
Stonechipping along
Hugh
#370
Posted 05 November 2011 - 04:37 PM
Of course I am not telling you what to do,just suggest
#371
#372
Posted 06 November 2011 - 06:27 PM
#373
Posted 07 November 2011 - 08:35 PM
Carlos thank you.
Minimuk - I'll get as much on as I can or can afford! Could you give me advice. The subframe on this Mini was replaced when my brother and sister in law had it. When I took it off there was a material sandwiched between the subframe and the underneath of the Mini's boot. It was like felt carpet underlay. It seemed to have caused no end of rust. Is there supposed to be something like that there?
Well I thought my patching days were passed but no. I went out to clean up the front bulhead a bit more. I had seen a bit of perforation (last photo on my last post) but when I explored it went right through!!
Oh dear!! so cut it out
Grand thick steel to get a weld on
I'll hopefully get the rest of it welded in tomorrow. Hey ho!
Welding along
Hugh
#374
Posted 07 November 2011 - 08:42 PM
its all coming along nicely though, good work
#375
Posted 07 November 2011 - 08:52 PM
Hugh
