My Poor Wee Mini Sky
#271
Posted 29 July 2011 - 11:11 AM
#272
Posted 05 August 2011 - 07:11 PM
Thanks again for the kind remarks - Chris, minimuk, my hero Deathrow and izzy.
Well, with my new blast furnace or grinder I tackled this horrible jacking point. I repaired rather than replaced, again. Please don't tell me I should use a new Heritage panel - remember its a ming's restoration!!
Cut it out and did a wee repair behind on the inner sill.
And then made this work of art - second attempt using my vice a socket and an old chisel.
Welded in and a new tab made as well.
And a check with the sill that its all in the right place.
Four hours to do just that!! I'm hopeless.
Hugh
#273
Posted 05 August 2011 - 07:30 PM
It's very rewarding doing a bit of fabrication like that. It's a shame it takes so long really as it's quite satisfying.
#274
Posted 05 August 2011 - 07:36 PM
#275
Posted 05 August 2011 - 09:00 PM
#276
Posted 08 August 2011 - 06:59 PM
I got the sill in today - my welding wasn't going so good. I made a real mess round the jacking point - I'll not show a close-up. There are definitely better days than others when it comes to welding.
Everything prepared - holes for plug welds, primed, bit of any old paint - Smoothrite I've had in the garage for years on the inner sill and I just scooshed a bit of the green Rustoleum I'm going to be using on the back of the sill.
And clamped in place
Welded in
Welds ground down, tidied and a wee scoosh of etch primer
So this side is almost repaired now.
I've still got to do the area just below the tail light but I'll need to turn Mini over for that.
The job seems never ending but I do think there is light showing at the end of the welding tunnel. I have to do some similar repairs to the other side but I only need to repair the bottom of the rear quarter rather than replace it. After that the welding still to do is the apex panels, wings and front panel and they are already cut out!! They will have to wait till the bottom is painted, the subframes renovated and its back on its wheels. Can hardly believe I'm starting to think about that!!
Welding on
Hugh
#277
Posted 08 August 2011 - 10:29 PM
Welding on,......
#278
Posted 12 August 2011 - 06:30 PM
And these are for you minimuk. Rear quarter just needs a couple of patches.
And of course it needs a sill. The front half of the sill has had some coversill put on it.
All in all a bit of a rusty mess.
So started by tackling the rear wheel arch. There is actually a small perforation to the inside.
So another wee repair done. Then tackled removing the sill. Here's what happens when a sill is just put over the rusted sill
And I certainly can't repair this jacking point
And left it like this
So a wee bit more done.
Grinding along
Hugh
#279
Posted 12 August 2011 - 07:12 PM
Grumbly Hugh
#280
Posted 12 August 2011 - 07:26 PM
You can rebuild it! You have the technology! Stronger! Faster! Able to leap tall buil... err.. Ok maybe not the last one
Good job Hugh cracking right along there
Chris
#281
Posted 12 August 2011 - 10:19 PM
I do like your progress and attack, after taking of the outer sill, the inner sill is not that bad a few cuts here and there, what you reckon?jacking point is shot for sure, you can make one for that side to.
welding on,...
#282
Posted 12 August 2011 - 11:34 PM
Just teething problems Hugh!I was a bit horrified this week to find the forum disappeared for over 24 hours and then came back in this format. It looks bonny but it is not nearly so user friendly. You can post less photos at a time. When you do several posts to get the photos up they seem to get joined into one post which seems nice but then you cannot edit as the big post has too many images to post!!
Grumbly Hugh
I've upped the max number of images to 40, I can't remember what it used to be, I thought it was 20. I've also turned off the auto merge posts feature.
That jacking point is something else! Maybe just best to buy a replacement if you want to keep it.
Beautiful work as always!
#283
Posted 13 August 2011 - 07:11 AM
Hugh
Edited by hughJ, 15 August 2011 - 07:49 PM.
#284
Posted 13 August 2011 - 10:36 AM
Don't worry about it, just keep up the good work
#285
Posted 13 August 2011 - 04:24 PM
Well it was really destruction today
Cut out inner sill and part of floor
This takes a lot longer than you would think
And made a panel to fill the space
It doesn't fit perfectly but I'll persuade it in! I've to give a coat of Smoothrite to the inside of the box-section and the back of the panel this evening. I'll hopefully weld it in on Monday evening. Back to teaching on Monday!! My lovely long teacher's holiday is over.
Graham I hope your OK. Haven't heard from you for a while. I do get worried. For a while I had Chris gone with a heart attack!! when I hadn't heard from him.
Grinding on
Hugh
18 user(s) are reading this topic
0 members, 18 guests, 0 anonymous users
